MWW1977
Gembird 300Mbps dongle not working in OpenElec with Kodi
Tue Jul 07, 2015 10:54 am
Hi Guys,
I have a question about a wifi dongle I bought for my Pi2.
I bought it hoping I would get the Pi2 up and running with NOOBS...but that didn.t turn out like I wanted to.
So I bought a OpenElec SD-card with Kodi installed. After I connected all the things to the Pi2 (mouse, keyboard and wifi dongle) I plugged in the power supply. Every thing worked great...except for the wifi dongle. My network did not pop-up on the wifi settings screen. So I don't think it's supported in OpenElec.
Is that true? Can I make it work? Or do I have to buy a new wifi dongle?
Thanks in advance for helping!
With kind regards,
Mike
Re: Gembird 300Mbps dongle not working in OpenElec with Kodi
Tue Jul 07, 2015 11:00 am
MWW1977 wrote:Hi Guys,
With kind regards,
Mike
http://www.gembird.com/item.aspx?id=8282
RTL8192EU Chipset is afaiaa not natively supported in OpenElec
fyi NOOBS is an installer/chooser and not the Operating System, you would likely had installed Raspbian OS, see this for Raspbian Driver:
viewtopic.php?f=45&t=103989
RPi 4B 4GB (SSD Boot)..
MWW1977
Tue Jul 07, 2015 11:26 am
Thanks for your fast reply Fruitoftheloom! :D
Then I'll use this dongle for a windows pc and order a new dongle the reseller confirmed me would work with OpenElec.
They sell it specificly with Pi's with OpenElec/Kodi installed.
If it doesn't work I could sent it back to them. :D
https://www.sossolutions.nl/raspberry-p ... s/300-mbps
(it's a Dutch site)
Kind regards,
Mike
MWW1977
Tue Jul 07, 2015 11:31 am
Oh...one more thing: I want to take the Pi with me on my holliday so I can watch movies I have on a portable harddrive.
But when I connect the Harddrive to the Pi2 it's underpowered. Can this be solved with a powered USB hub?
Connect the harddrive to the powered USB HUB and the hub to the Pi2?
https://www.sossolutions.nl/raspberry-p ... chakelaars
Thanks!
Tue Jul 07, 2015 11:39 am
MWW1977 wrote:Oh...one more thing: I want to take the Pi with me on my holliday so I can watch movies I have on a portable harddrive.
Thanks!
The RPi B+ and 2B should be able to power a 2.5" USB Hard Drive see the following blog:
https://projects.drogon.net/testing-set ... berry-pi-b
In a nutshell you add the following to the 'config.txt' file
max_usb_current=1
MWW1977
Tue Jul 07, 2015 12:00 pm
Okay....but I'm not a programmer. Though this I can handle. :lol: Cut and past if you ask me.
But what I mean is that I don't know how to change the .txt file or in what program for that matter.
Can I just unplug the SD-card...insert it in a windows pc and change the file with notepad?
Or must it be done from within kodi? But Kodi is a media program...not editor.
At that part I get stuck. :oops:
Tue Jul 07, 2015 1:00 pm
MWW1977 wrote:Okay....but I'm not a programmer. Though this I can handle. :lol: Cut and past if you ask me.
Yes that will work ;)
MWW1977
Tue Jul 07, 2015 1:53 pm
Okay, thanks for your reply.
I'm a bit scared because I already wrecked a 16GB sd-card and my OpenElec is just working fine now. :mrgreen:
But I'll give it a go tonight! ;)
MWW1977
Wed Jul 08, 2015 11:46 am
I've inserted the SD-card into a windows laptop....opent up the config.txt file but I get stuck again.
The artikel say's to put the line "safe_mode_gpio=4" or "max_usb_current=1" in the config file....but it doesn't say were it needs to be written down. :(
From the file contence I see it is devided into "chapters" like Memory, Overclocking, overscan, ect. but I have no idea were to put the "max_usb_current=1". I'm to scared I f*ck up the coding and need to buy another pre-installed OpenElec sd-card :mrgreen:
Done here you see the content of my config.txt file.
I hope someone can direct me to the location were I need to put that line in.
Thanks in advance from a newbie. :geek:
#      This file is part of OpenELEC - http://www.openelec.tv
#      Copyright (C) 2009-2014 Stephan Raue (stephan@openelec.tv)
#      Inspired and partly copied from:
#  http://youresuchageek.blogspot.fr/2012/09/howto-raspberry-pi-openelec-on.html
#  OpenELEC is free software: you can redistribute it and/or modify
#  it under the terms of the GNU General Public License as published by
#  the Free Software Foundation, either version 2 of the License, or
#  (at your option) any later version.
#  OpenELEC is distributed in the hope that it will be useful,
#  but WITHOUT ANY WARRANTY; without even the implied warranty of
#  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
#  GNU General Public License for more details.
#  You should have received a copy of the GNU General Public License
#  along with OpenELEC.  If not, see <http://www.gnu.org/licenses/>.
# Bootloader configuration - config.txt
# Memory (System/GPU configuration )
# default GPU memory split (do not change if you do not know what you are doing)
  gpu_mem=128
# SDRAM size based GPU memory split, uncomment and setup to override 'gpu_mem'
  gpu_mem_256=112
  gpu_mem_512=160
  gpu_mem_1024=256
# Overclocking settings
# WARNING: Do not change/enable if you do not know what you are doing!
#          The System may become unstable or you can have data corruption or
#          you can loose your warranty if you set wrong settings
# please read: http://elinux.org/RPi_config.txt#Overclocking_configuration
# Overclock mode settings.
# default recommended values are: arm_freq | core_freq | sdram_freq | over_voltage
# no overclocking               :    700   |    250    |    400     |      0
# mode 'Modest'                 :    800   |    300    |    400     |      0
# mode 'Medium'                 :    900   |    333    |    450     |      2
# mode 'High'                   :    950   |    450    |    450     |      6
# mode 'Turbo'                  :   1000   |    500    |    500     |      6
# arm_freq=700
# core_freq=250
# sdram_freq=400
# over_voltage=0
# set to 'force_turbo=1' to disable dynamic overclocking (you can lose your warranty!)
  force_turbo=0
# If you have any data corruption using Turbo Mode and overclocking
# try with this setting uncommented
# If this still fails, try to use Medium mode without "over_voltage=2"
# If it ultimately keeps failing, forget about this until it gets fixed
# Use a more conservative mode that will works fine in any cases:
# initial_turbo=30
# Overscan settings
# Make display smaller to stop text spilling off the screen
# see also http://www.raspberrypi.org/phpBB3/viewtopic.php?f=67&t=15700
# overscan_scale=1
# disable_overscan=1
# Adapt overscan values to your needs
# overscan_left=57
# overscan_right=59
# overscan_top=20
# overscan_bottom=20
# various settings see also: http://elinux.org/RPi_config.txt
# Force HDMI even if unplugged or powered off
# hdmi_force_hotplug=1
# Doesn't sent initial active source message.
# Avoids bringing CEC (enabled TV) out of standby and channel switch when
# rebooting.
  hdmi_ignore_cec_init=1
# License keys to enable GPU hardware decoding for various codecs
# to obtain keys visit the shop at http://www.raspberrypi.com
# decode_MPG2=0x00000000
# decode_WVC1=0x00000000
# decode_DTS=0x00000000
# decode_DDP=0x00000000
# End of default configuration
# all values below this line were inserted from config.txt.bk (your old config)
# and can be merged with the above values
JimmyN
Wed Jul 08, 2015 12:18 pm
You can add it to the very bottom, it doesn't matter. If you want dress it up to look like the rest and add a little info on how the settings got there do this
# User added configuration
max_usb_current=1
safe_mode_gpio=4
MWW1977
Wed Jul 08, 2015 12:34 pm
Thanks for the reply JimmyN. :D
But in your code add there's still the "safe_mode_gpio=4" line.
From reading the artikel provided by fruitoftheloom I thought the "max_usb..." code replaced the "save_mode..." code.
But I'll just put it in the config.txt file. Don't think it can do much harm.
Thanks again for helping me out!
With kind regards,
Mike Wellink
The Netherlands
JimmyN
Wed Jul 08, 2015 12:42 pm
I was just providing an example and clarifying where you could put changes, not the actual entries.
I guess I shouldn't have used both entries in my example.
MWW1977
Wed Jul 08, 2015 1:04 pm
:oops: :oops: :oops:
Hahahahaha...I told you I'm a newbie... :lol: :lol: :lol: :lol: :lol:
