This will run all parts of the GPU at 500 MHz. I've been using that on all my RPis (B, B+, 2 B)without any problems.expandables wrote:Hi I have the gpu frequency to 500 "gpu_freq=500" is that a stable overclock? Also what benefit will the raspberry pi have with the gpu overclocked.
I've been using that on 4 RPis (B, B+, B2) and it seems to work. I don't so much 3d stuff but all my pi3D programs and demos work well.dom wrote:I doubt 3D will run at 500MHz, so you may have problems there. (Try hello_teapot to check if it works).
In general I'd say v3d_freq=300, h264_freq=400 and core_freq=500 will work on most Pi's (but all this is overclocking, so no guarantees).
If you are lucky and have a faster than average Pi you may get higher, but I've never seen 3D working at 500MHz.
Hardware accelerated VLC maybe (I don't know why you're not using Omxplayer) but chromium doesn't have any hardware acceleration. And you won't get a major speed boost from overclocking.expandables wrote:This "gpu_freq=500" help chromium and the hardware accelerated vlc in any way?
