davezx wrote:Is that any good tho for a motor? I'm not using a stepper motor just a plain straight forward motor.
Will the one I've got do the job?
Can't just keep buying loads of bits to make a motor simply go forward and backwards.
Was originally told the pi would do it in its own and then a nano v3, then the one I just ordered, now this one, lol.
Unfortunately you seem to buy something as soon as it is mentioned without understanding how it can be used.
I told you that the Nano V3 was an example of a small arduino microcontroller that could do the same job as the Pi (controlling the opening and closing of the screen either by directly controlling a Servo or by driving a H-bridge motor driver chip).
This wasn't inteaded as a suggestion that you buy one, just that you needed to decide whether a Pi was the correct microcontroller for your application.
You then bought a Nano V3.
We told you that a motor driver was necessary but the one you have chosen is designed to sit on top of an Arduino Uno. You don't have anything with the Pin Layout of an Arduino Uno so the driver board you have chosen is unsuitable for the task at hand. Wiring up the board you have purchased to either a Pi or a Nano V3 would be possible but complex.
I agree with Joan that the level of complexity is beyond your current skill.
The
L9110S that Joan suggests is much smaller and far easier to connect.
The seller of the L293D you selected offers a 60 day return policy, if you contact him/her they may not have sent it out yet. (if they have sent it then you are out by £1.70 as it will cost more than that to return it).
Doug.
