Loltuttifruitti
I can't move or delete files( I don't have permission)
Wed Jul 01, 2015 10:27 pm
I'm ne to the raspberry pi stuff and anyway I installed Apache to start a web server and it works. I'm using raspbian(noobs package). Only problem is the when I go to /var/www/index.html, it won't let me delete it or move it because permission is denied. How do I get permission? Thanks!
W. H. Heydt
Re: I can't move or delete files( I don't have permission)
Thu Jul 02, 2015 4:14 am
First...do an "ls -l" to find out who owns the files (probably root). This is more for information than anything else.
Second be *certain* that you are doing what you want to do. Take a backup anyway in case you make a mistake.
Third, prefix you commands with "sudo" (e.g. "sudo rm <filename>" to delete a file). That will mean that you are running the command as if you were logged in as root. Root has permission to do anything to the system...when a command is run by root, permissions are ignored.
Note: You can run a single command as root that will delete *all* files on the system. I am *not* going to give that command in this Forum because someone would be sure to use it and then complain that it actually worked...and blame me that it did.
Loltuttifruitti
Thu Jul 02, 2015 6:54 pm
W. H. Heydt wrote:First...do an "ls -l" to find out who owns the files (probably root). This is more for information than anything else.
How do I become root on th desktop interface? I'm on the actual desktop trying to drag files. Will I have to move them from my usb to a folder through terminal? If so what comman would that be?
Thu Jul 02, 2015 7:58 pm
Loltuttifruitti wrote: How do I become root on th desktop interface? I'm on the actual desktop trying to drag files. Will I have to move them from my usb to a folder through terminal? If so what comman would that be?
Open an LXTerminal window and use the sudo -i command. Everything you do in the window after that runs as root.
solo2500
Mon Oct 29, 2018 2:52 pm
Is there a way to do this using the file manager?
I'm a total novice, non-programer (...basically a hack.)
W. H. Heydt
Mon Oct 29, 2018 3:27 pm
Yes...but running as root is discouraged because if you forget that you're running as root, you can create what used to be described as "On a clear disk, you can seek forever." Basically, if you are logged in as root, then everything you run will be as root. If you can't figure it out from there, you probably shouldn't be doing it anyway. See my first comment in this thread.
(I have an old SuSE system that addressed this issue by having the desktop wallpaper covered in exclamation points and "bomb" images...all on a bright red background. No way to miss that you are logged in as root.)
HawaiianPi
Mon Oct 29, 2018 6:59 pm
As others have said, if you don't know how to do this already, you will probably end up messing up your system.
But to answer your question, open a terminal and enter,
gksudo pcmanfm
to launch a root file manager.
You can add a Root File Manager entry to the Raspbian menu.
Menu > Preferences > Main Menu Editor
Click on Accessories, then new item and fill out as follows:
You should also see an entry for a Root Terminal that is not enabled, so I enabled that while I was in there.
And here are a couple of custom icons I made for them (matching the Pixel/RPi Desktop style icons).
Image Image
Grab those pics and click on the default icon in the corner of the box you edit when creating the root file manager menu entry (also located in properties when editing the menu), then select your desired picture.
*** Using this improperly will will break your system! ***
