Ranppa
16x2 LCD display to show ram and CPU info
Wed Jul 01, 2015 11:37 am
Could someone please explain to can i get the CPU and ram info to show on my 16x2 LCD screen?
what commands do i neet to put in the python code?
Thanks in advance.
Re: 16x2 LCD display to show ram and CPU info
Wed Jul 01, 2015 3:04 pm
What CPU and RAM info do you mean?
GET_IP_CMD = "hostname --all-ip-addresses"
GET_TEMP_CMD = "/opt/vc/bin/vcgencmd measure_temp"
TOTAL_MEM_CMD = "free | grep 'Mem' | awk '{print $2}'"
USED_MEM_CMD = "free | grep '\-\/+' | awk '{print $3}'"
Ranppa
Wed Jul 01, 2015 3:07 pm
CPU usage in %, used ram/free ram. I already got it working with average load and CPU temp.
Ranppa
Wed Jul 01, 2015 7:59 pm
What do i put in the brackets to display ram info on the lcd?
JimmyN
Fri Jul 03, 2015 10:40 am
I have one Pi set up with a LED bargraph for an "at a glance" status that shows CPU temp, RAM used, and CPU load.
Another Pi is set up with a 16x2 LCD that scrolls through system information like IP address, CPU load, CPU clock speed, CPU temp, disk space/usage, etc.
To display CPU usage on the LCD I use 'psutils' to fetch the info. Here are those bits from the script.
import psutil
# .. more script
# .. more script
while True:
    CPU_usage = psutil.cpu_percent(interval = .5)
    lcd.message('CPU Load   %s%% ' % (CPU_usage))
Your LCD "print" command may be different from "lcd.message" depending on which LCD library you're using.
For RAM usage I wasn't sure which values I wanted to display; Total, Free, or Used. So i use a function that collects all three and then I can decide what to display on the bargraph or LCD. For the LED bargraph I only show 'Used', but for the 2 line LCD display I use 'Free' and 'Used' since I have two lines to fill anyway. Or I can easily switch and use Total/Free or Used/Free
import os
# .. more script
# .. more script
# Return RAM information (unit=kb) in a list
# Index 0: total RAM
# Index 1: used RAM
# Index 2: free RAM
def getRAMinfo():
    p = os.popen('free')
    i = 0
    while 1:
        i = i + 1
        line = p.readline()
        if i==2:
            return(line.split()[1:4])
while True:
    RAM_stats = getRAMinfo()
    RAM_used = round(int(RAM_stats[1]) / 1000,1)
    RAM_free = round(int(RAM_stats[2]) / 1000,1)
    lcd.message('RAM Used %sMB   \n' % (RAM_used))
    lcd.message('RAM Free  %sMB   ' % (RAM_free))
Maybe that will help you out a little bit
ame
Fri Jul 03, 2015 11:11 am
Not entirely on-topic, but I just got a Nokia 5110 LCD module from DealExtreme and hooked it up to my Pi.
It was extremely cheap, easy to set up and looks nice.
It might be a bit small for some applications, but it makes a nice 6 line by 14 character display. With backlight!
Ranppa
Sun Jul 05, 2015 9:55 am
JimmyN wrote:I have one Pi set up with a LED bargraph for an "at a glance" status that shows CPU temp, RAM used, and CPU load.
import psutil
# .. more script
# .. more script
while True:
import os
# .. more script
# .. more script
# Index 1: used RAM
# Index 2: free RAM
def getRAMinfo():
    i = 0
    while 1:
        i = i + 1
        line = p.readline()
        if i==2:
while True:
I used your code and got it working! I have no experience what so ever in coding but with a few cups of coffee i figured this out! Thank you all for your replies!
MetalizeYourBrain
Sun Mar 26, 2017 12:23 pm
What about showing the CPU temperature? I've not been successfull using this code:
#more code and imported all the correct libraries
def cpu_tempC():
    f = os.popen("/opt/vc/bin/vcgencmd measure_temp")
    for i in f.readlines():
        mytemp += i
        mytemp = mytemp[5:-3]
#a while loop that shows correctly other informations
    lcd.lcd_display_string("%s" % cpu_tempC + chr(223) + "C", 4)
The code compiles correctly but the display reports this:
<fuction cpu_tempC at 0x767c13f0>°C
I'm using a 20x4 LCD and everything works well.
Sun Mar 26, 2017 12:44 pm
Try this
def cpu_tempC():
    mytemp = ""
        mytemp += i
        return mytemp
print("%s" % cpu_tempC() + chr(223) + "C", 4)
