I found this Python code to take images as fast as possible, but i don't know how to stack all images fast to a 3D stack of images.
import io
import time
import picamera
#from PIL import Image
def outputs():
stream = io.BytesIO()
for i in range(40):
# This returns the stream for the camera to capture to
yield stream
# Once the capture is complete, the loop continues here
# (read up on generator functions in Python to understand
# the yield statement). Here you could do some processing
# on the image...
#stream.seek(0)
#img = Image.open(stream)
# Finally, reset the stream for the next capture
stream.seek(0)
stream.truncate()
with picamera.PiCamera() as camera:
camera.resolution = (640, 480)
camera.framerate = 80
time.sleep(2)
start = time.time()
camera.capture_sequence(outputs(), 'jpeg', use_video_port=True)
finish = time.time()
print('Captured 40 images at %.2ffps' % (40 / (finish - start)))Best regards, Agustín
