Wed Jul 01, 2015 2:41 pm
- use a DAC with a 0.1V voltage reference, which you can generate dividing a 1.024V voltage reference by ten before feeding it to the Aref pin.
- use an appropriate voltage divider on a 0-3v3 or 0-5v dac
- as joan suggested, use a digital port
If you need more current, add an opamp circuit
http://Mikronauts.com - home of EZasPi, RoboPi, Pi Rtc Dio and Pi Jumper @Mikronauts on Twitter
Advanced Robotics, I/O expansion and prototyping boards for the Raspberry Pi
