aleynasarcanli
NFC Problem
Mon Jun 29, 2015 7:34 am
Hello everyone, I need some help. How can I use my nfc shield with raspberry pi ? my shield link below. I dont know which pins I must use, I must comunicate them with python. Please help, this is my homework :(
texy
Re: NFC Problem
Mon Jun 29, 2015 8:21 am
Hi and welcome to the forum.
Well for one thing you need to do your own homework, otherwise you will not learn anything ;)
Secondly you have not supplied the promised link to for the nfc shield................
Texy
aleynasarcanli
Re: NFC Problem
Mon Jun 29, 2015 11:12 am
oh, I am sorry :) I forgot link, ok. I added. I am searching for a long time, but i didnt find anything about it, now I dont have a much time, i must comunicate raspberry pi and nfc shield, and I must make python script for take any nfc card's uid. shield link below
http://www.seeedstudio.com/wiki/NFC_Shield_V2.0
Re: NFC Problem
Mon Jun 29, 2015 11:44 am
It's an SPI device, so connect the MISO, MOSI (on the ICSP header) and pin#10 (CS) to the SPI pins on your RPi.
You should then be able to use the python-spidev library to communicate with it.
aleynasarcanli
Re: NFC Problem
Mon Jun 29, 2015 11:50 am
Thank you mr Lawson, but I tried everything, it is not working. I cannot find when I run cat /dev/spidev :(
Re: NFC Problem
Mon Jun 29, 2015 11:56 am
SPI needs to be enabled with a config.txt parameter
dtparam=spi=on
Once you add that then /dev/spidev0.0 and /dev/spidev0.1 will appear.
aleynasarcanli
Re: NFC Problem
Mon Jun 29, 2015 11:58 am
Ok, I am trying now :)
aleynasarcanli
Re: NFC Problem
Mon Jun 29, 2015 2:07 pm
mr Lawson, I found raspberry spi pins and attached it to the nfc board, nfc pin(10 cs pin) attached raspberry pi pin gpio 8 [ce(0)] and my code below, nothing working, always response "0" do you any idea ?
import spidev
import time
spi = spidev.SpiDev()
spi.open(0,0)
while True:
   resp = spi.xfer2([0x00])
   print resp[0]
   time.sleep(1)
Re: NFC Problem
Mon Jun 29, 2015 2:30 pm
I'd start by reading it with an Arduino, since you've got ready made code for that.
aleynasarcanli
Re: NFC Problem
Mon Jun 29, 2015 5:12 pm
Anyone for help ? :(
texy
Re: NFC Problem
Mon Jun 29, 2015 7:01 pm
Looking at the spec it's rated at 5v. The pi requires a 3v3 input so maybe it's not comparable.
Texy
iyosch
Re: NFC Problem
Mon Jul 06, 2015 5:17 am
hello.. have you tried this viewtopic.php?f=45&t=78966&p=560905&hilit=pn532#p560905
to setup the hardware and the libnfc setup for raspberry pi
and perhaps this https://learn.adafruit.com/adafruit-nfc ... ing-libnfc
and i guess someone already make your project http://www.instructables.com/id/Attenda ... -software/
Tell me if you made progress.. hope that helps..
