Note => I build raspi2 in large case.
Greetings
I still not buy RPi2 . I will buy it..My goal ; creating a speedy device and use it.İ have amateur C++ ( i still continue study ) , it can be solve this problem ?gkreidl wrote:Don't do it. Even the suggested overclocking to 1 GHz didn't work on any of my RPi2s reliably. Heat wasn't the problem (CPU temperature never went beyond 50 deg). My older Pis (B, B+) could all be overclocked to at least 1 GHz and 500 MHz for the GPU.
It seemed to work, but when the CPU was really stressed I got kernel panic or crashes.
Using better software will give you much more performance gain.
Wrongfruitoftheloom wrote:The RPi does not additional cooling aids, unless you are in the middle of the Sahara Desert at Noon
The RPi2 B is Quad Core so as above stated better software![]()
This overclock and supercooling is someone coming from the x86 / Windows world
The only Windows for the Pi is a special IOT version which is not the Windows that most people know. You will need a full PC running Windows 10 (or Windows 7 and a few tricks) to build the software and connect to it. There is no desktop. It will not run the usual Windows apps.Can wrote:Another one : İf i install windows , it will be requires cooling ?
