khashayarbayati
Bluetooth Problem
Wed Jun 24, 2015 11:07 am
I'm trying to do some Bluetooth programming with a Raspberry PI, but I have a problem. I want to use 'get_available_port' method, when I run the .py code, an AttributeError accrues, that it says " 'module' object has no attribute 'get_available_port ". I would be very thankful if someone could help me!
elParaguayo
Re: Bluetooth Problem
Wed Jun 24, 2015 1:03 pm
Post your code and full error message please.
That error can often arise when you give your script the same name as a python module that you're trying to import. i.e. if your script has the line:
import bluetooth
don't call your script bluetooth.py
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
khashayarbayati
Wed Jun 24, 2015 1:20 pm
here is my code:
import bluetooth
server_sock=bluetooth.BluetoothSocket( bluetooth.RFCOMM )
port = bluetooth.get_available_port( bluetooth.RFCOMM )
server_sock.bind(("",port))
server_sock.listen(1)
print "listening on port %d" % port
uuid = "1e0ca4ea-299d-4335-93eb-27fcfe7fa848"
bluetooth.advertise_service( server_sock, "FooBar Service", uuid )
client_sock,address = server_sock.accept()
print "Accepted connection from ",address
data = client_sock.recv(1024)
print "received [%s]" % data
client_sock.close()
server_sock.close()
#and this is my error
'module' object has no attribute 'get_available_port'
thank u for replying :)
elParaguayo
Wed Jun 24, 2015 1:34 pm
Please use code tags when pasting python code.
Also paste the full error message, it usually gives you a line number, file name details as well.
Looking at the PyBluez documentation (I assume this is the module you're using) it says this:
get_available_port(protocol)
deprecated. bind to port zero instead.
So maybe try commenting out your line and just setting port to zero.
Return to “Python”
