ive done a lot of research and found that I should use a global variable to do the counting, so ive added that and it works well as I can print it to console but I cannot get it to appear on my gui, any help would be great.
im currently attempting to show the run_counter() on label3
import Tkinter as tk
root = tk.Tk()
from Tkinter import *
import threading
import time
root.geometry("720x100")
root.title("Countdown Tester")
stop = threading.Event()
run_counter = 0
def reset():
button["text"] = "Begin Countdown"
label["text"] = "Countdown Finished"
label.config(bg='dark red', fg='white')
label2["text"] = ""
label2.config(bg='black', fg='white')
root.timer = root.after(1000, label.update)
root.update_idletasks()
stop.set()
def _5():
label2["text"] = "5"
label2.config(bg='orange', fg='black')
time.sleep(1)
def _4():
label2["text"] = "4"
time.sleep(1)
def _3():
label2["text"] = "3"
time.sleep(1)
def _2():
label2["text"] = "2"
time.sleep(1)
def _1():
label2["text"] = "1"
time.sleep(1)
def _0():
label2["text"] = "0"
time.sleep(1)
global run_counter
run_counter += 1
root.update()
print run_counter
def run():
while not stop.isSet():
if not stop.isSet():
_5()
_4()
_3()
_2()
_1()
_0()
def script():
label["text"] = "Countdown Began"
label.config(bg='blue', fg='white')
run()
def toggle_text():
if button["text"] == "Begin Countdown":
button["text"] = "Stop Countdown"
label.config(bg='green', fg='black')
stop.clear()
t1 = threading.Thread(target=script)
t1.daemon = True
t1.start()
else:
label["text"] = "Countdown Stopped"
label.config(bg='red', fg='white')
label2["text"] = ""
stop.set()
def on_exit():
root.destroy()
canvas = Canvas(width=720, height=100, bg='black')
canvas.grid(rowspan=26, columnspan=20, sticky='W,E,N,S')
button = Button(root, text="Begin Countdown", font='-weight bold', width=17, command=toggle_text)
button.grid(padx=10, pady=10, row=10, column=0, sticky='W,E,N,S')
button2 = Button(root, text=" Quit ", font='-weight bold', command=on_exit)
button2.grid(padx=5, pady=10, row=10, column=1, sticky='W,E,N,S')
label = Label(root, text=" ", width=20, font='-weight bold', background='black')
label.grid(padx=5, pady=10, row=10, column=2, sticky='W,E,N,S')
label2 = Label(root, text=" ", width=11, font='-weight bold', background='black')
label2.grid(padx=5, pady=10, row=10, column=3, sticky='W,E,N,S')
label3 = Label(root, text=run_counter, width=11, font='-weight bold', background='white')
label3.grid(padx=5, pady=10, row=10, column=4, sticky='W,E,N,S')
root.resizable(width=FALSE, height=FALSE)
root.mainloop()
