I have posted already in the Compute module forum but was asked to post here as well:
I have a circuit which switches on and off a LED connected to the GPIO25 which is connected to a transistor and a pull down resistor. Also there is a 3.3V signal coming from a PIR motion detector which is read with GPIO23. This was working all fine with a Raspberry Pi B.
Now I have changed to a Raspberry Pi B 2 where I thought the GPIO is design compatible. But my circuit is not working any more.
The GPIO25 has a voltage about 2.6V when setting it to high which is not enough to drive the transistor.
Also the input from the PIR is not recognized anymore because the voltage level is around 2.8V.
Do I have to change the pull down resistor for the Raspberry Pi 2? If yes how to change it?
