mmkw43
Raspian CPU monitor?
Fri Jun 19, 2015 3:38 pm
Ok -- have a lengthy python/tkinter program I've been writing and almost done with it, it works great but one thing I hadn't been keeping an eye on is the cpu monitor.
But then, how accurate, what value does it have?
I can reboot, start python, open my program and start it under the command prompt and it will shoot up to 100% -- talking about that little cpu monitor in the upper right corner in raspian, just left of the clock.
What's weird though, is it stays at 100%, even if I close everything -- python included. Like I say, the program runs perfectly -- no errors -- there is a lot going on with 2 threads, and of course tkinter in there also. Is there a better way to see what actually is happening? maybe a command or soemthing I can put in the software that will show me resources being used?
Thought I'd try a PI2 also -- using a model B right now. Guess I may have to just comment out blocks of code to see where the hog is.
ghp
Re: Raspian CPU monitor?
Fri Jun 19, 2015 3:48 pm
in a console window, enter 'top'.
'top' is a monitor, which displays processes, cpu per process, memory and some more stuff.
Regards,
Gerhard
mmkw43
Fri Jun 19, 2015 4:15 pm
thanks --
first entry says 2366 root running about 87% (python 3.2) -- is this the tkinter stuff you think?
ghp
Fri Jun 19, 2015 4:20 pm
the entry is for 'python'. When no other process is using python, then it is tkinter.
Regards,
Gerhard
mmkw43
Fri Jun 19, 2015 4:54 pm
89 total tasks, 88 sleeping most of the time
(3) running tasks --
(1) top -- of course
and 'python' only shows as a running task very occasionally, as well as 'pi'
177k memory used 268k free
so even with 100% cpu showing, it sounds like I'm ok right? is my situation typical?
mmkw43
Sat Jun 20, 2015 2:45 am
answering my own post -- apparently it's because I have a nonstop while true loop in my code -- makes sense.
davef21370
Sat Jun 20, 2015 4:18 am
Put a small delay in your loop to free up the CPU.
time.sleep(0.1)
Dave.
Apple say... Monkey do !!
Return to “Python”
