aditya3098
Solder pad for raspberry pi model b rev 2 (original).
Fri Jun 19, 2015 12:33 pm
The SD card slot on my raspberry pi broke when I was inserting a card. I tried desoldering the old slot to replace with a nice new one I found at my local parts store. It almost worked when the DAT1 solder pad just broke off, just leaving a small patch of circuit board without any soldermask or solder. What can I do? Do I really need a new pi? More importantly, is there any alternate place where the DAT1 pin comes up?
Laurens-wuyts
Re: Solder pad for raspberry pi model b rev 2 (original).
Fri Jun 19, 2015 12:42 pm
Can you post a picture please?
So we can see the actual dammage.
Laurens
Laurens-wuyts
Fri Jun 19, 2015 12:47 pm
On the schematics you can see that every data pin is connected to a resistor. If you can solder very well, you can try to connect the pad here using a wire.
Laurens
aditya3098
Fri Jun 19, 2015 1:46 pm
I found the resistor. I am going to solder it tommorow (more light, and I will be less tired). I found that it was resistor 50 I needed to solder.
Thanks.
aditya3098
Sat Jun 20, 2015 5:44 am
Ok, I tried it, it didnt work. I have no idea what went wrong. It just sits there with the power led on, no activitiy...
Laurens-wuyts
Sat Jun 20, 2015 7:02 am
Can you post pictures please?
I'll see if I see anything strange.
Laurens
aditya3098
Sat Jun 20, 2015 10:12 am
I don't have my camera now, I will post them soon...
Do you want me do desolder the wires (I tried directly wiring an SD card when the reader method didn't work)?
aditya3098
Sat Jun 20, 2015 10:57 am
Wait, just realised the solder was shorting out somewhere, so now its working!
Thanks. Also, as I now use a 6 inch copper wire for the sd card connections, I bypassed the resistor, as the wire had about 30 ohms of resistance.
drgeoff
Sat Jun 20, 2015 11:36 am
aditya3098 wrote:Also, as I now use a 6 inch copper wire for the sd card connections, I bypassed the resistor, as the wire had about 30 ohms of resistance.
Either it is not copper or it is incredibly thin. :)
Laurens-wuyts
Sat Jun 20, 2015 2:12 pm
I'm glad it worked. :)
Laurens
aditya3098
Thu Jun 25, 2015 10:28 am
Considering how small the solder joint is, its VERY thin. Also, I checked, turns out its not copper. Its some alloy.
Return to “Advanced users”
