Franklin89
GStreamer
Wed Jun 17, 2015 9:15 pm
Hi evereyone
I am new to this forum and i am having a problem with my Raspberry Pi 2 Model B.
I folowing this tutorial: http://www.raspberry-projects.com/pi/pi ... -gstreamer
But i am having trouble getting gstream to work.
i get following output:
Reading package lists... Done
Building dependency tree
Note, selecting 'libgstreamer1.0-dev' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-plugins-base' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-audiosource' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-audiosink' for regex 'gstreamer1.0'
Note, selecting 'libgstreamer1.0-0' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-visualization' for regex 'gstreamer1.0'
Note, selecting 'libgstreamer1.0-0-dbg' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-omx-dbg' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-plugins-ugly' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-plugins-base-dbg' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-plugins-base-doc' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-gnomevfs' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-doc' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-plugins-bad' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-plugins-base-apps' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-tools' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-omx' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-libav' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-plugins-good' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-plugins-bad-dbg' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-plugins-bad-doc' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-videosink' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-videosource' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-pulseaudio' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-plugins-ugly-dbg' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-plugins-good-dbg' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-plugins-ugly-doc' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-alsa' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-plugins-good-doc' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-libav-dbg' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-x' for regex 'gstreamer1.0'
gstreamer1.0-libav is already the newest version.
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
gstreamer1.0-omx-dbg : Depends: gstreamer1.0-omx (= 1.0.0.1-0+rpi13rpi1) but 1.2.0-1 is to be installed
E: Unable to correct problems, you have held broken packages.
...can anybody help me?
Thanks a lot
Franklin
gkreidl
Re: GStreamer
Thu Jun 18, 2015 6:43 am
gstreamer-1-0 is now in the Foundation repositories and installed by default. Mixing it up with the other repo only leads to troubles.
Minimal Kiosk Browser (kweb)
Franklin89
Re: GStreamer
Thu Jun 18, 2015 8:09 am
Okay thanks for the Info...
So i do not have to install it if i want to stream a video?
If i try the command it says that it cant find the gst-launch command...
gkreidl
Re: GStreamer
Thu Jun 18, 2015 9:03 am
check with
ls /usr/bin/gst*
If the tools you're looking for are missing, run
sudo apt-get install gstreamer1.0-tools
Who is online
Users browsing this forum: davidcoton, jbillauer and 13 guests
