kuba_moo
u-boot very slow kernel loading
Mon Jun 15, 2015 1:49 pm
I'm using latest u-boot to enable dual-boot on my CM-based board. Everything works fine except the MMC performance. This is a sample boot log:
U-Boot 2015.07-rc2-dirty (Jun 11 2015 - 17:03:17 +0200)
DRAM:  412 MiB
WARNING: Caches not enabled
RPI Compute Module
MMC:   bcm2835_sdhci: 0
reading uboot.env
In:    serial
Out:   lcd
Err:   lcd
Net:   Net Initialization Skipped
No ethernet found.
Hit any key to stop autoboot:  0
Booting normal system...
switch to partitions #0, OK
mmc0(part 0) is current device
reading zImage
4003816 bytes read in 48930 ms (79.1 KiB/s)
As you can see it takes almost a minute to load the kernel. Does anyone else, who is using u-boot, experience a similar problem? I'm not sure if it's related to the fact that I'm using the Compute module's on-board memory. Have anyone used u-boot on a SD card-based system successfully?
Any input would be greatly appreciated, thanks!
Vogtinator
Re: u-boot very slow kernel loading
Wed Jun 17, 2015 4:03 pm
I also encountered this issue on the newest openSUSE rpi2 builds and it's indeed very annoying...
A fix was published on the mailing list: http://lists.denx.de/pipermail/u-boot/2 ... 16852.html
I tested it and it seems to work fine, loading speed exceeds 1.4 MiB/s.
I uploaded my working build: https://www.dropbox.com/s/jw6xgfg3adwcy ... ?dl=0&s=sl
