hj-alceol
feedback on usage
Sun Jul 15, 2012 11:44 am
Hello everybody;
here some comments about the use of raspberry pi (B) an may DIY projects
First : I am not using the raspberry as a toy that you forget after playing with for a couple of weeks.
I am currently using the board as an home automation gateway coupled with a set of arduinos.
On the positive side :
- The perfect microcomputer/microcontroler for DIY projects (home automation, multmedia ...)
- Extremly simple to use when you know linux.
- easy to marry with the Arduino family by using the usb port
Things to keep:
- Ethernet port , usb port, dvi port, audio port
- sdcard reader (not microsd)
- Operating system: Linux
Thing to avoid:
- Windows, Android on the board
To be improved:
- Four connector sides is too much. 2 connectors sides will be nice. Form factor should be revisited. Have a look at http://apc.io
- The SDCard reader is a good idea. Dont replace it with à microSDcard reader as the only microSD cards available are in class 4 and therfor very slow.
- The SDCARD reader is very cheap. The plastic rail breaks easy . I had to glue on top of the reader a small pcb to fixit.
- Mounting holes on the pcb are missing it is a mess to fixit the board somewhere
New features, having in mind the cost. It will be nice to have:
- An rtc chip + battery on board
- 1,2 sata port(s) for multmedia purposes (DVD and/or HDDRIVE)
- A second pair of usb ports on the pcb as internal connectors but not as external connectors
- Memory (this one could be expensive !)
- a 2 or 4 pins connector for the power supply
Anyway the job the rasberry team made is still fantastic. Bravo, bravissimo :D
Henri
AndrewS
Re: feedback on usage
Mon Jul 16, 2012 11:58 am
hj-alceol wrote:New features, having in mind the cost. It will be nice to have:
The RPi Foundation have said many times that the primary consideration when designing the board was low cost. And they've also said that there's no plans for any hardware changes or future board designs yet - they want it to keep it a fixed, stable platform.
Can be easily added via an I2C or SPI interface.
You can add DVD/CD/HDD drives via USB ;) But note that RPi doesn't provide MPEG2 acceleration, so it currently can't play DVD video (movie) discs.
You can either add a USB hub, or look at http://www.raspberrypi.org/phpBB3/viewt ... =29&t=8686 if you really want an "internal connector" :)
You can provide power via 2 of the pins on the GPIO header http://elinux.org/RPi_Hardware#Power
Narf03
Wed Jul 18, 2012 5:29 pm
I would like to add
Need 1 or 2 screw holes for easy mounting
Align the USB with RJ45
Add a cheap heat sink on top of ram
kadamski
Wed Jul 18, 2012 5:38 pm
Narf03 wrote: Need 1 or 2 screw holes for easy mounting
There is not enough space for that. It was considered but was not possible.
Narf03 wrote: Align the USB with RJ45
There is not enough space for that. Just look at the board.
Narf03 wrote: Add a cheap heat sink on top of ram
It's not needed at all. There is no problem with heat on RPi without head sink so it would be just a waste.
You have to remember that Foundation had some goals designing RPi and unfortunaly there where some tradeoffs to make. Without them, RPi (as it is now) couldn't be made. You can read about it's history and those tradeoffs in this forum and on main site to better understand why it is the way it is.
AndrewS
Wed Jul 18, 2012 11:38 pm
kadamski wrote:
Narf03 wrote:Align the USB with RJ45
I think I read the the USB port sticking out so far was actually a mistake with the component footprint, which didn't get noticed until too late, when it would have been too expensive to redesign the board.
