Some careful use of a MK I index finger should be able to find the hot spot on the processor. It's probably best to boot the RPi, run it hard and hot, shutdown, pull the power before feeling around for the hot spot.Heater wrote: 2) How hard can it be to figure out which chip is the processor?
Heater wrote:The confusion here seems to be that jerryemerydelacruz received a Pi with a heat sink.
Now, as far as I can recall, there is no mention of heat sinks in any of the Raspberry Pi Foundations documentation. Why would there be? It does not need one.
Ergo, jerryemerydelacruz's supplier is responsible for this confusion and should provide documentation and answer questions about any heat sink they shipped.
jerryemerydelacruz, who did you get your Pi from?
I wouldn't argue against that. I also received sets of heat sinks with cases I've purchased. I put one on the LAN chip on my Pi2B, but not the 2836. I currently have a power supply HAT on top of the Pi2B which has a cooling fan right over the 2836, but I don't normally have the fan turned on. The other heat sinks I ended up with are on the 2835 and LAN chip on my B+, but I don't use that Pi often. I do believe that heat sinks aren't really necessary for most uses of the Pi.jerryemerydelacruz wrote:ktb,
I used the heatsink on the processor after identifying the processor by running the numbers. As an electronic engineer, all silicon runs better if cool, that's why millions are spent on refrigeration at server cites. If someone gives you a heat-sink, put it on whatever chip that's near.
Too be fair the Raspberry Pi Foundation did not do this, you down stream supplier did. Well, what the heck, just stick that heat sink on to the processor and forget it. At least it saves adding it to a land fill.I expect this kind of difficulty from a company like Microsoft (oops, I still cringe at the thought of trying to decipher those old Fortran manuals) , not from Raspberry pi. But we perceiver.
It's great isn't it? What makes it even better of course is the community of users and this very forum. Have fun.Thanks for the info. Will probably have to take advantage of this forum now that I'm registered. Haha. Love this little gadget.
No, it hasn't. A heatsink is not needed.debslosingit wrote:I see this thread has gone the direction of might as well attach it
You don't need it. Chuck it in a drawer or something., but where and to what? And how?
Stick it to the back of your phone. It'll do just as much good thereame wrote:No, it hasn't. A heatsink is not needed.debslosingit wrote:I see this thread has gone the direction of might as well attach itYou don't need it. Chuck it in a drawer or something., but where and to what? And how?
