payturr
How to properly overclock?
Sat Jul 14, 2012 9:09 pm
Hey guys, my Pi is supposed to arrive sometime in the next 2 weeks, and I plan to overclock it, I just want to know exactly how to do it. I would like to know where I'd go to change the FSB frequency & how I should go about it - small increments like 20MHz increases every x amount of hours? And how high can I go without overvolting or causing the board to heat up? I plan to have it on 24/7 with no breaks (just gonna turn the peripherals off when I'm not using it) and I want it to be kept at a safe temperature. So how exactly do I overclock it and how high should I go thats healthy for my board? Thank you!
PS: This is the first computer I own that I'll be overclocking :geek:
Nburnes
Re: How to properly overclock?
Sun Jul 15, 2012 3:29 am
http://elinux.org/RPi_config.txt#Overclocking_options
You simply make a text document named config.txt, place it in /boot with the settings you want and off you go. Most Pi's seem to easily do 800mhz, mine personally can get to 930mhz stable without any overvolting (which voids warranty btw). Then gpu freq is obviously the entire GPU overclocking, but my reading in the thread in this forum named "Overclocking" http://www.raspberrypi.org/phpBB3/viewt ... =29&t=6201 seems to cause instabilities, so like others I do simply a core freq increase.
payturr
Sun Jul 15, 2012 3:57 am
Thanks man, I can just put it at 800MHz off the bat or should I start at like, 720MHz and work my way up?
Sun Jul 15, 2012 6:10 am
I'd start a 800. Pretty much guaranteed it can do that. Read the linked thread above- has everything you need.
“My wife said to me `...you’re not even listening`.
I thought, that’s an odd way to start a conversation.."
payturr
Sun Jul 15, 2012 12:26 pm
It wouldn't be too much? Cause I don't want the board to like, keel over just from a swift overclock to 800MHz
sjfaustino
Sun Jul 15, 2012 12:50 pm
As long as you don't overvolt, AFAIK the most that will happen is the Pi will simply not boot or be unstable with errors and/or kernel panics.
In case that happens, just take the SD out of the Pi, insert into a computer, change the setting to something more conventional, save, pop the SD out of the computer and insert it back in to the Pi.
Happy testing :)
EDIT: forgot to mention, you really should do a burnin test after the overclock since the Pi just booting isn't a good test of stability. You should do an apt-get install cpuburn and use it to test for stability.
EDIT2: nevermind the cpuburn, it seems it doesn't work on the RPi. Just do:
sudo apt-get install bc
time echo "scale=2000; a(1)*4" | bc -l
payturr
Sun Jul 15, 2012 1:21 pm
Well I can do that, but I don't know - just seems like too much to put on the Pi. Does everyone just jump to higher number clock speeds or?
Sun Jul 15, 2012 1:42 pm
Some people are getting 1Ghz without overvolt, so 800 is not going to be a problem. That's where I would start. If it doesn't start (But I think it will) you just need to drop it back in config.txt. No harm done. Only overvolting breaks the warranty.
aaa801
Sun Jul 15, 2012 1:51 pm
Ive got mine upto 1200mhz with a 8 overclock
normaly you can get to 900 without a overclock
payturr
Sun Jul 15, 2012 2:28 pm
Well I understand the whole overvolting issue, but I just wanna make sure that I could just jump from 700MHz to 800MHz with no issue, cause if it doesn't boot I rather just take my time and work my way up, cause I really HATE using Windows, in all honesty.
Sun Jul 15, 2012 4:51 pm
Dom is working on a patch to allow you to force a boot to standard settings using a jumper, so if you overclock it and it won't boot, you can still reboot to default, edit the config and recover the system. No windows involved. But I seriously doubt you will have any problems at 800Mhz.
teh_orph
Sun Jul 15, 2012 10:53 pm
Why does the clock speed default to 700 MHz if we're expected to get such higher speeds at the same voltage? Do you know what percentage won't be able to go past > 750 MHz? (I'm thinking about yield etc)
Btw is the 700 MHz thing chosen by the foundation, or is that just what Broadcom guarantees?
dom
Sun Jul 15, 2012 11:09 pm
teh_orph wrote:Why does the clock speed default to 700 MHz if we're expected to get such higher speeds at the same voltage? Do you know what percentage won't be able to go past > 750 MHz?
700MHz is guaranteed across all chips and across the temperature range. Almost all chips will run faster, especially at normal "room" temperature.
Lob0426
Mon Jul 16, 2012 3:28 am
My RasPi seems to dislike anything over 800MHz. I have a theory that this is due to a below spec output from one of the voltage regulators. Probably one in the SoC. Vindicators likes to run at 900MHz with no overvolt. His starts wavering around 950. Is there a test point, that you can get to to test the voltage to the ARM Clock? It would be interesting to see what the different RasPii are turning out for voltage compared to the MHz. I seem to remember that there is more than one regulator in the SoC.
Motorola Lapdock with Pi2B
http://rich1.dyndns.tv/
Flojer0
Mon Jul 16, 2012 5:29 am
I just jumped by 100's until I hit instability and pulled back until I found it again. I got 950 without over-volt and 1200 with. Reading what others say it does appear VERY likely that you'll hit 800MHz without over-volt and 1GHz with over-volt very easily.
I do have some minor overclocking experience on my PC and have read quite a good deal on it. Even on a full desktop if you aren't pushing voltages up then all you have to do is watch for heat problems, and it has already been established by many in the know that heat isn't a problem with the pi. Allegedly even with over-volt it sounds like it is more the voltage than excess heat that will do it in.
Lob0426
Mon Jul 16, 2012 3:49 pm
My 3v3 rail is at 3.28. My 1v8 Rail is at 1.8. So it is not the RG1(1v8) or RG2(3v3). I have been over the schematics and have not found a point to test for the voltage to the ARM processor Clock. It must be off of a regulator internal to the SoC. There are multiple 1v8 lines into the SoC but only one 1v8 regulator.
lucien_roach
Tue Jul 17, 2012 12:07 am
aaa801 wrote:Ive got mine upto 1200mhz with a 8 overclock
What do you mean by an "8 overclock"?
I tried googling it but could find anywhere else that used this expression.
AndrewS
Tue Jul 17, 2012 1:57 am
Lob0426 wrote:My 3v3 rail is at 3.28. My 1v8 Rail is at 1.8. So it is not the RG1(1v8) or RG2(3v3). I have been over the schematics and have not found a point to test for the voltage to the ARM processor Clock. It must be off of a regulator internal to the SoC. There are multiple 1v8 lines into the SoC but only one 1v8 regulator.
There are a whole bunch of VDD pins http://elinux.org/RPi_BCM2835_Pinout maybe you'll be able to probe some of them from underneath if you're careful / clever ?
AndrewS
Tue Jul 17, 2012 2:01 am
I suspect he means an "8 overvolt" - http://elinux.org/RPi_config.txt#Overcl ... figuration
Vindicator
Tue Jul 17, 2012 2:15 am
I have been using openarena as my stability test if I have it wrong the main menu will not appear but if it is right the main menu does appear in openarena.
Occasionally it will get into the main menu but will crash when going into the game itself.
In X I was able to run 950 cpu 500 ram and 350 gpu but in openarena 900 500 320 is what works.
I was able to get into X at 1000 but the keyboard would die out sometimes.
If you are more worried about ,spelling, punctuation or grammar you have probably already missed the point so please just move on.
lucien_roach
Tue Jul 17, 2012 1:17 pm
I thought this too, I just wondered since I'm unfamiliar with the RPi hardware.
aaa801
Tue Jul 17, 2012 9:04 pm
indeed i did :P
Snipez
Mon Jul 30, 2012 2:11 am
I run my CPU at 930mhz seems the best.
FX4
Tue Jul 31, 2012 12:04 am
Lob0426 wrote:My RasPi seems to dislike anything over 800MHz. I have a theory that this is due to a below spec output from one of the voltage regulators. Probably one in the SoC. Vindicators likes to run at 900MHz with no overvolt. His starts wavering around 950. Is there a test point, that you can get to to test the voltage to the ARM Clock? It would be interesting to see what the different RasPii are turning out for voltage compared to the MHz. I seem to remember that there is more than one regulator in the SoC.
More than likely your die just came from the edge of the wafer. Center die are faster and edge die are slower. This is caused by optical distortion in the photolithography process.
jerrylamos
Fri Aug 03, 2012 12:42 pm
"properly" I've no technical familiarity with RasPi. I'm usually testing Ubuntu Alpha's and Beta's on netbook, notebook, tower. My interest in the RasPi is the lively forums.
What's running here is
sudo leafpad /boot/config.txt
arm_freq=900
core_freq=450
sdram_freq=450
shutdown, power off/on. Reboot wasn't happy.
This got wide margins on the display so
framebuffer_width=1366
framebuffer_height=768
overscan_top=-16
overscan_bottom=-16
save, shutdown, power off/on.
Running O.K. No overvolt, no heat sinks - will if I run across appropriate heat sink and adhesive here in the states.
Your milage may vary....
Jerry
Return to “Advanced users”
