Earthenware
Please recommend a wireless adaptor
Mon Jun 01, 2015 2:08 am
So I went to Maplins and asked for a wireless adaptor that works with a Raspberry Pi. Apparently, the one I got can be made to work after a lot of fiddling. That's not what I want.
This page (http://elinux.org/RPi_USB_Wi-Fi_Adapters) lists a number of adapters that are described as "preinstalled", but I don't want to assume that means I can just plug it in and go.
Can anyone please recommend a wireless adapter that I can just plug in and that's it? I'm not bothered about speed or cost.
Thanks in advance.
Re: Please recommend a wireless adaptor
Mon Jun 01, 2015 4:51 am
Earthenware wrote:So I went to Maplins and asked for a wireless adaptor that works with a Raspberry Pi. Apparently, the one I got can be made to work after a lot of fiddling. That's not what I want.
Thanks in advance.
http://swag.raspberrypi.org/collections ... ifi-dongle
RPi 4B 4GB (SSD Boot)..
odepotmike
Sat Aug 08, 2015 5:29 am
i have been using the one from canakit and I just pluged it in and it worked
mahjongg
Sat Aug 08, 2015 5:40 am
The only one that is officially supported, is the official wifi adapter from the swag store, and that is NOT the same one as the one from canakit.
However, Raspbian probably contains drivers for several WiFi chipsets, but you mileage may vary with those.
Sat Aug 08, 2015 12:01 pm
mahjongg wrote:The only one that is officially supported, is the official wifi adapter from the swag store, and that is NOT the same one as the one from canakit.
RPF support this one as same BCM WiFi Chipset
https://www.pi-supply.com/product/broad ... spberry-pi
mahjongg
Sun Aug 09, 2015 12:21 am
both are using the same broadcom chip, so what is actually supported (officially) is any wifi adapter based on that broadcom chip.
The BCM43143.
Sun Aug 09, 2015 10:37 am
This one: http://shop.pimoroni.com/products/usb-h ... fi-adaptor appears to be based on the same Broadcom chipset.
Sun Aug 09, 2015 11:03 am
DougieLawson wrote:This one: http://shop.pimoroni.com/products/usb-h ... fi-adaptor appears to be based on the same Broadcom chipset.
Yes same as I posted :roll: different supplier :shock:
Sun Aug 09, 2015 11:14 am
You made the mistake of thinking I'd bother to follow your link before posting.
ame
Sun Aug 09, 2015 11:48 am
I bought whatever was cheapest (and smallest) at DeaExtreme. It worked.
InsideJob
Wed Aug 12, 2015 12:04 am
LOL, the only one officially supported is a complete nightmare. Used to be you needed fwcutter and/or NDIS wrapper to make a Broadcom WiFi card work.
I think I'm going to switch to Debian for ARM since "officially" it supports everything. :roll:
Wed Aug 12, 2015 1:30 am
InsideJob wrote:LOL, the only one officially supported is a complete nightmare. Used to be you needed fwcutter and/or NDIS wrapper to make a Broadcom WiFi card work.
in September 2014 the RPF Raspbian Operating System included support for BCM43143,
https://www.raspberrypi.org/blog/new-ra ... s-releases
I do not know if supported in other Linux Distro's without additional firmware, but details here:
https://wireless.wiki.kernel.org/en/use ... /brcm80211
tinkertechie
Mon Aug 17, 2015 1:04 pm
I'm using EDUP Wireless USB Nano card EP-N8508GS and it was plug-and-play with Python OS.
However, if you are planning to experiment with Windows 10 IoT Core, I suggest you stick to the Official Raspberry Pi WiFi dongle to save you some headaches later. See the link below for the supported WiFi adapters have been tested on Windows 10 IoT Core:
http://ms-iot.github.io/content/en-US/w ... Fi_Devices
