hhqhamza
Raspberry Pi 2 Model B 1GB Display
Sun May 31, 2015 2:49 pm
Hello
Is there any way to attach thisImage to this Image. Thanks
BMS Doug
Re: Raspberry Pi 2 Model B 1GB Display
Mon Jun 01, 2015 6:55 am
The problem is that the USB might get in the way a bit.
Too increase the height of the display screen add on board you could add a stacking header between the Pi and the display board.
Doug.
B.Goode
Mon Jun 01, 2015 7:05 am
The same supplier has a version of that adapter card for an RPi 2B: http://www.watterott.com/en/RPi-Display-B-Plus
hhqhamza
Thu Jun 04, 2015 5:13 pm
guys i tried all its not working. Is this screen compatible with pi2 or not?
ThomasS
Thu Jun 04, 2015 5:15 pm
hhqhamza wrote:guys i tried all its not working. Is this screen compatible with pi2 or not?
Have you tried a stacking header as suggested above?
ThomasS
B.Goode
Thu Jun 04, 2015 5:22 pm
hhqhamza wrote: Is this screen compatible with pi2 or not?
Maybe you should be asking that question of the manufacturer/supplier?
But it seems to me that if the original version of the adapter card was compatible with an RPi Model 2 then -
a) it would work;
but
b) there would have been no need for the supplier to introduce a later version for the Model 2.
Conversely, since the supplier did see the need to make a modified version, and your experience is that the original doesn't work, maybe it is reasonable to assume that it is not compatible in some way?
awatterott
Thu Jun 11, 2015 5:26 pm
The RPi-Display works also with the RPi 1 model B+ or RPi 2 model B. But you need a stacking header.
A connection with a flat cable is not possible because then every 2nd pin is swapped.
Rgds,
Andreas
mikronauts
Thu Jun 11, 2015 5:37 pm
make sure you do:
sudo apt-get update
sudo apt-get install
You may also need to check for a newer driver, as the Raspberry Pi 2 changed the I/O base address, and a *LOT* of software needs re-compilation after a minor change before it will work on an RPi2
