I am actually building a simple project which consist in communicating and setting up a capacitive-multitouch LCD assembly (display plus touch) to an RPi 2.
The first step, i.e., communication, is just solved. I used an LCD o HDMI converter, programmed a couple of things in the RPi and its done.
Regarding the touch, I have been able to connect the screen via I2C communication port, and using some "tools" I have detected my peripheral in the I2C port (i2c-tools), process the information it sends me when a touch event is sensed over the digitizer (python) and, finally, do a mouse click event when and where I detect the touch event. Here the code:
import smbus
import time
import subprocess
bus = smbus.SMBus(1)
# For knowing your screens memory address type on the terminal: i2cdetect -y 1
addr = 0x38 # Memory address of the peripheral.
clicked = False # A boolean variable for the click algorithm.
while True:
try:
#Read the bytes from the registers we want.
#In this example only 1 touch point is implemented.
rg3 = bus.read_byte_data(addr,0x02) #Number of active touch points.
rg4 = bus.read_byte_data(addr,0x03) #Horizontal zone of point 1: 128-132
rg5 = bus.read_byte_data(addr,0x04) #Horizontal value of point 1 in the previously measured horizontal zone: 0-255
rg6 = bus.read_byte_data(addr,0x05) #Vertical zone of point 1: 0-3
rg7 = bus.read_byte_data(addr,0x06) #Vertical value of point 1 in the previously measured vertical zone: 0-255
# NOT USED IN THIS PROGRAMM, NOT MULTITOUCH
# rg10 = bus.read_byte_data(addr,0x09) #Horizontal zone of point 2: 128-132
# rg11 = bus.read_byte_data(addr,0x0A) #Horizontal value of point 2 in the previously measured horizontal zone: 0-255
# rg12 = bus.read_byte_data(addr,0x0B) #Vertical zone of point 2: 0-3
# rg13 = bus.read_byte_data(addr,0x0C) #Vertical value of point 2 in the previously measured vertical zone: 0-255
if rg3 == 1 and rg4 >= 128 and clicked == False: #Entry only if 1 touch point is detected and if it is located into the digitizer active area.
#Point 1 horizontal coordinates transformation.
horiz = (rg4 - 128)*255 + rg5
#Point 1 vertical coordinates transformation.
vert = rg6*255 + rg7
subprocess.call(["xdotool","mousemove",str(horiz),str(vert)]) #Move mouse to the desired point.
subprocess.call(["xdotool","click","1"]) #Perform a mouse click event where the mouse is placed.
clicked = True
elif rg3 == 0 and clicked == True: #No touch points are detected.
clicked = False
time.sleep(0.01) #Time waiting for repeat the main loop.
except:
break
Anyway, now I want to become this touch screen system more realistic, with 2 touch points. And, why? For example, I have designed an screen keyboard in java, and I would like to test if the "Shift" button I programmed works fine. So, how could I do it?
Here are all the commands that can be used from the "Xdotools" python module:
http://www.semicomplete.com/projects/xd ... e_commands
I tought using something like "mousedown for the first point" and "mouseclick for the second one". ¿Any good idea?
Thanks to all in advance. Regards.
