Pwl2
File transfer problem
Tue May 26, 2015 7:11 pm
I am trying to transfer a text file (using Filezilla in SFTP mode) created in notepad on Win 7 to a Pi running Rasbian, that is to be processed for use by fortune. The file looks fine on Win and under nano on the Pi
quote 1
quote 2
but when I run
strfile -c % test test.dat
I tells me there is only one line the length of the file and when I run fortune the cookie is all the file.
If I create the file in nano it works as expected in strfile / fortune bur on transfer and editing in notepad I get
%quote 1%quote 2%
I have tried transferring as asciii, binary and using a zip file. Any Ideas as to what I have wrong? I know fortune is trivial but the underlying problem concerns me.
Paul
Pwl2
kusti8
Re: File transfer problem
Tue May 26, 2015 7:34 pm
I would think it's because windows uses different ways to signify a new line. Use something like notepad++ and switch to Unix new line.
There are 10 types of people: those who understand binary and those who don't.
Joe Schmoe
Tue May 26, 2015 8:04 pm
Yeah, it certainly sounds like yet another iteration of the DOS vs. Unix line endings problem.
There are tools called "dos2unix" and "unix2dos" that supposedly handle this, but it's not really worth the hassle. (To put it another way, these tools have never really worked well for me...)
Anyway, the first thing to do is to load the file up into vi (vim);
vi file
Then do:
:se ff?
That will tell you the fileformat. Now, assuming that says "dos", then you can do:
:se ff=unix
And finally, press ZZ (that's right, two capital Zs) to save and exit the file.
That will convert it to unix format. Then it should work...
Pwl2
Fri May 29, 2015 9:48 am
Thanks. It was the line ending problem. I thought ASCII mode FTP took care of that.
Pwl2
Pwl2
Jednorozec
Fri May 29, 2015 10:59 am
Pwl2 wrote:Thanks. It was the line ending problem. I thought ASCII mode FTP took care of that.
FTP text mode should take care of that but filezilla seems to screw up. Try http://winscp.net/eng/index.php - it's always worked well for me.
The most important leg of a three legged stool is the one that's missing.
It's called thinking. Why don't you try it sometime?
