hewesy
Battery issues on a wildlife cam project
Mon May 25, 2015 7:22 pm
I'm hoping this is the best place for this....
I've built a wildlife cam using;
An original model B Pi
Pinoir camera board
LED IR light (12v)
12v to 5v step down for powering the Pi
12v 4800ma battery pack
Running on mains, everything runs fine (I'm using a script to compare images then fire a high res pic if different).
On the battery pack though, it runs for 5-6mins then all stop. I did flick the battery off/on whenIi tried it again today and it ran for 2hrs before I shut it down.
Any thoughts? I've put a meter on it and battery drain is very low. It should last 5-6hrs by my rubbish maths!
mikronauts
Re: Battery issues on a wildlife cam project
Mon May 25, 2015 7:41 pm
What was the current used @ 12V from the battery with everything, including IR light running?
hewesy wrote:Hi,
Pinoir camera board
LED IR light (12v)
http://Mikronauts.com - home of EZasPi, RoboPi, Pi Rtc Dio and Pi Jumper @Mikronauts on Twitter
Advanced Robotics, I/O expansion and prototyping boards for the Raspberry Pi
