Leroy8
"Wifi Config" icon disappeared
Thu May 21, 2015 12:38 am
Using Raspbian Wheezy. It was on a SD card included with purchase. Install successful.
There was originally a "Wifi Config" icon in one of the categories accessed by drop down menu on upper left (may have been under "Accessories" category but I don't remember). When I selected the icon a screen would come up to allow selection of configuration parameters such as encryption method. The icon is gone.
The icon is shown here:
https://learn.adafruit.com/adafruits-ra ... up/setting
-up-wifi-with-raspbian
Any ideas on how to recover the "Wifi Config" icon?
Re: "Wifi Config" icon disappeared
Thu May 21, 2015 8:18 am
Leroy8 wrote:Using Raspbian Wheezy. It was on a SD card included with purchase. Install successful.
The desktop has changed see
https://www.raspberrypi.org/blog/#anoth ... ace-update
Retired disgracefully.....
......to a more gentile life !
Leroy8
Thu May 21, 2015 4:07 pm
Thanks. I see the changes described inn the link, but I don't understand how my system changed without any know command issued.
I now have a new icon on the upper panel for "Wifi networks (dhcpcdui) Settings" but the icon for wpa_gui (the Wifi Config icon) has disappeared from the drop down menu/preferences. What caused the change?
ktb
Thu May 21, 2015 7:06 pm
I don't know what changes have been made because I haven't tried the new UI/net mods.
Do you still have wpa_gui on your system?
ls /usr/sbin | grep wpa
wpa_gui
Perhaps the wpa_gui.desktop file has changed. Perhaps it is now hidden from the menu?
cat /usr/share/applications/wpa_gui.desktop
[Desktop Entry]
Version=1.0
Name=wpa_gui
Comment=Graphical user interface for wpa_supplicant
Exec=/usr/sbin/wpa_gui
Icon=wpa_gui
GenericName=wpa_supplicant user interface
Terminal=false
Type=Application
Categories=Qt;Network;
Keywords=wlan;wifi;configuration;
Perhaps your Pi has some file system corruption.
Perhaps the menu cache is corrupted.
Leroy8
Fri May 22, 2015 6:42 am
ktb wrote:I don't know what changes have been made because I haven't tried the new UI/net mods.
wpa_gui
[Desktop Entry]
Version=1.0
Name=wpa_gui
Icon=wpa_gui
Terminal=false
Type=Application
Yes to your question... I still have wpa_gui, but it does not have an icon in the drop down menu.preferences. I discovered if I type "wpa_gui" in a command window, the wpa_gui window comes up as before. I'm a beginner and don't understand what the code above does.
cpcbegin
Wed May 27, 2015 7:30 pm
Now I have this new icon but when the cursor is over there shows the message "dhcpcd not running"
I try clic, doble clic and clic with secondary buttom to select "Wifi Networks (dhcpcdui settings), but nothing hapends.
The wifi networks is running but I can't reconfigure with this icon.
I try also run
sudo /etc/init.d/dhcpcd restart
But I get
[FAIL] Not running dhcpcd because /etc/network/interfaces ... failed!
[FAIL] defines some interfaces that will use a DHCP client ... failed!
Trucos y recetas para raspberry pi:
http://malagaoriginal.blogspot.com.es/search/label/raspberry%20pi
metalj
Wed May 27, 2015 9:14 pm
Startx
Start menu
Choose Run from bottom of menu
Type in wpa_gui
Backspace 28 times :)
Lob0426
Thu May 28, 2015 1:02 am
I had the same problem a couple of weeks ago. I could not find or run wpa_gui. I ended up reloading from a backup.
Motorola Lapdock with Pi2B
http://rich1.dyndns.tv/
cpcbegin
Thu May 28, 2015 7:11 pm
I solved the problem editing /etc/network/interfaces and commenting all lines with dhcp
jward
Mon Jun 22, 2015 4:46 pm
The solution used by cpcbegin also worked for me. Before using this solution, I saw on the boot screen a message that said "Not running dhcpcd because /etc/network/interfaces defines some interfaces that will use a DHCP client". After commenting two lines in /etc/network/interfaces that contained "dhcp" and rebooting, dhcpcd started automatically.
