hamza
fetchmail > /dev/null\
Tue May 19, 2015 11:38 pm
hi
i execute ed this command using command terminal
and it is working correctly, but when I but put it inside bash scrpit, then it give me the following error
fetchmail: WARNING: Running as root is discouraged.
fetchmail: no mailservers have been specified.
#!/bin/bash
so, what is the correct command way inside bash??
Re: fetchmail > /dev/null\
Wed May 20, 2015 8:11 am
Why are you running the bash script as root?
What is wrong with just running it as "pi" (or your normal user)?
hamza
Wed May 20, 2015 12:09 pm
How can I run the comnand or script as pi user ??or another user?
kusti8
Wed May 20, 2015 12:20 pm
How are you running the script?
It should be simply:
./script.sh
Wed May 20, 2015 12:21 pm
Um, you just run it.
You'd need to be doing something different to run it as root or another user, like using sudo for example.
How are you running the script and the command at the moment?
Joe Schmoe
Wed May 20, 2015 12:29 pm
I think a lot of people get the impression (from reading the posts on this board) that if anything at all goes wrong with a command, putting "sudo" in front of it will fix it.
pluggy
Wed May 20, 2015 12:33 pm
Joe Schmoe wrote:I think a lot of people get the impression (from reading the posts on this board) that if anything at all goes wrong with a command, putting "sudo" in front of it will fix it.
I think a lot of people just put sudo in front of commands irrespective whether it works or not as a standard user.
Joe Schmoe
Wed May 20, 2015 12:49 pm
Quite so. Why mess around?
pluggy
Wed May 20, 2015 2:22 pm
Because sometimes the application doesn't like being run as root ? (which brings us nicely back to square one).
Joe Schmoe
Wed May 20, 2015 2:41 pm
It was a joke.
It's like what I call "The kill -9 problem". Once people learn about "kill -9", they never use anything else...
I could write an essay about "kill -9", but suffice it to say that the range of cases where "kill -9" works and ordinary "kill" doesn't, is actually pretty small.
