unhappyelf
RPi 2 and NRF24L01
Tue May 19, 2015 9:05 pm
Ok I have been scratching my head for a while over this(I think its a big hole now) but I have had a hard time getting the RF24Network library to work on both devices. I think I finally fixed the Arduino but the Pi is not working right. Any help would be appreciated.
Output from the Arduino, I believe it is working fine(disregard the 11111111 I have an GPIO chip that is reporting it status)
Arduino_Output
Output from the Pi, these values change a lot. I know this is prob a SPI issue but I am at a loss to determine the issue.
Pi_Output
I am using the RF24 library from http://tmrh20.github.io/RF24/, I am also using the RF24Network examples.
unhappyelf
Re: RPi 2, nrf24l01+pa+lna, and Arduino
Wed May 20, 2015 9:31 pm
Ok, I completely re-flashed the OS changed the config.txt to enable SPI and ran through the instructions here http://tmrh20.github.io/RF24/RPi.html. Things still are not looking right.
Any thoughts?
unhappyelf
Thu May 21, 2015 7:54 pm
Ok I looked through bcm2835.h and bcm2835.c. It is trying to use /proc/device-tree/soc/ranges to pull the address block of the device. I went to that file and it appears to be empty. Any ideas still?
unhappyelf
Re: RPi 2 and NRF24L01
Fri May 22, 2015 8:39 pm
So I verified the wireless works on two ardunio's just fine. Still seems to be a initialization issue with the radio on the Pi. Please, any help would be appreciated.
RetiredProgrammer
Sat May 30, 2015 11:10 pm
It looks like you have different data rates and different CRCs. They need to match if Arduino and RPi are to communicate.
danjperron
Sun May 31, 2015 1:23 am
Yes retiredProgrammer is right.
Data rate needs to b the same.
Channel needs to be the same.
Transmit device need to send the address of a received device. The 5 byte device ID don't seems to match also.
You could check my post about the nRF24L01.
viewtopic.php?p=720838#p720838
unhappyelf
Mon Jun 01, 2015 8:26 pm
This I understand, however when using the library and example I can never get it to set the correct channels. It was my understanding that when using the RF24Network library that the channel and data rate would set automatically like it dies on the Arduino. Do these settings need to be explicitly configured on the Pi? I had assumed it was a communication issue during setup of the radio.
