Unfortunately my computer case is plastic, but would a radiator do? Also how would you go about avoiding carpets?gordon77 wrote:Just make sure you discharge yourself by touching the metal work on something like a PC, which should be earthed.
Avoid things that generate static like carpets, synthetic clothing.
In the UK you MUST have your water and gas pipes bonded to the mains earth, so a radiator (as long as it's not painted) will work.ThomasS wrote: Unfortunately my computer case is plastic, but would a radiator do? Also how would you go about avoiding carpets?
Doesn't your pc have metal on the back or sockets with metal surrounds ? Just touch one of them or anything metal thats earthed.ThomasS wrote:Unfortunately my computer case is plastic, but would a radiator do? Also how would you go about avoiding carpets?gordon77 wrote:Just make sure you discharge yourself by touching the metal work on something like a PC, which should be earthed.
True, didn't think of that. A bit awkward to get to so I think I'll use pipes as Dougie Lawson suggested. But on the subject of carpets, how do you avoid picking up static from them? Will slippers work or do the carpet-like inner soles produce static?gordon77 wrote: Doesn't your pc have metal on the back or sockets with metal surrounds ? Just touch one of them or anything metal thats earthed.
You ground yourself periodically.ThomasS wrote:True, didn't think of that. A bit awkward to get to so I think I'll use pipes as Dougie Lawson suggested. But on the subject of carpets, how do you avoid picking up static from them? Will slippers work or do the carpet-like inner soles produce static?gordon77 wrote: Doesn't your pc have metal on the back or sockets with metal surrounds ? Just touch one of them or anything metal thats earthed.
What I've done in the past is make sure things are cold (to avoid being scolded), take a shoe & sock off and rest a big toe on a bare metal part of the radiator or pipe. It's not as easy as an earthing strap.W. H. Heydt wrote:You ground yourself periodically.ThomasS wrote:True, didn't think of that. A bit awkward to get to so I think I'll use pipes as Dougie Lawson suggested. But on the subject of carpets, how do you avoid picking up static from them? Will slippers work or do the carpet-like inner soles produce static?gordon77 wrote: Doesn't your pc have metal on the back or sockets with metal surrounds ? Just touch one of them or anything metal thats earthed.
I agree its difficult to avoid them all together but just be aware of them. Choose a room that doesn't have them to work in if possible, and if you have walked across carpets ensure you discharge yourself before working on any electronics.ThomasS wrote:True, didn't think of that. A bit awkward to get to so I think I'll use pipes as Dougie Lawson suggested. But on the subject of carpets, how do you avoid picking up static from them? Will slippers work or do the carpet-like inner soles produce static?gordon77 wrote: Doesn't your pc have metal on the back or sockets with metal surrounds ? Just touch one of them or anything metal thats earthed.
Not just that, but in older houses it was only required that the Cold water pipes be Earthed, not the Hot ones or the heating sytsem, and in newer houses there may be plastic pipes in part of the water system which can effectively isolate the system from the Earth and there is no requirement to electrically Earth any pipes which are isolated like that.ThomasS wrote: I didn't know radiators couldn't be painted to discharge static and that's probably where I went wrong with my Pi cameras.
OK, so are you saying that painted radiators discharge static (as long as they're not isolated)? Also do you have any idea re the wristband question?rpdom wrote:Not just that, but in older houses it was only required that the Cold water pipes be Earthed, not the Hot ones or the heating sytsem, and in newer houses there may be plastic pipes in part of the water system which can effectively isolate the system from the Earth and there is no requirement to electrically Earth any pipes which are isolated like that.ThomasS wrote: I didn't know radiators couldn't be painted to discharge static and that's probably where I went wrong with my Pi cameras.
Yes the wrist band will discharge static whatever the source.ThomasS wrote:First thanks to everyone for their brilliant advice. Thanks Gordon! I think I'll do as you suggest and get a wristband after all to avoid doing complicated manoeuvres with one foot on the radiator. Thanks to Dougie Lawson as well; I didn't know radiators couldn't be painted to discharge static and that's probably where I went wrong with my Pi cameras. One last question - will wristbands offset static created by carpets and static clothing? ('offset' is complex scientific vocabulary)
Thanks! We really need a favourite button on this forumgordon77 wrote:Yes the wrist band will discharge static whatever the source.ThomasS wrote:First thanks to everyone for their brilliant advice. Thanks Gordon! I think I'll do as you suggest and get a wristband after all to avoid doing complicated manoeuvres with one foot on the radiator. Thanks to Dougie Lawson as well; I didn't know radiators couldn't be painted to discharge static and that's probably where I went wrong with my Pi cameras. One last question - will wristbands offset static created by carpets and static clothing? ('offset' is complex scientific vocabulary)
No, I'm saying that you shouldn't really trust a radiator as a point to discharge static, whether they are painted or not.ThomasS wrote:OK, so are you saying that painted radiators discharge static (as long as they're not isolated)? Also do you have any idea re the wristband question?
OK thanks. I'm planning on using the back of my computer case as Gordon suggested anyway.rpdom wrote:No, I'm saying that you shouldn't really trust a radiator as a point to discharge static, whether they are painted or not.ThomasS wrote:OK, so are you saying that painted radiators discharge static (as long as they're not isolated)? Also do you have any idea re the wristband question?
The wristband is the best way to discharge and prevent any type of static build-up in your body, as long as it is connected to a good earthing point.
