I'm working on a tiny project to learn how to show real-time data from a analog source on a display connected to the Raspberry through HDMI.
This is what I've planned; I've written some code, which now displays the irradiance directly on the screen... it works perfect.... but it's plain text, not very nice looking
#!/usr/bin/python
import time, signal, sys
from Adafruit_ADS1x15 import ADS1x15
def signal_handler(signal, frame):
#print 'You pressed Ctrl+C!'
sys.exit(0)
signal.signal(signal.SIGINT, signal_handler)
#print 'Press Ctrl+C to exit'
ADS1015 = 0x00 # 12-bit ADC
ADS1115 = 0x01 # 16-bit ADC
# Initialise the ADC using the default mode (use default I2C address)
# Set this to ADS1015 or ADS1115 depending on the ADC you are using!
adc = ADS1x15(ic=ADS1015)
print("\033c");
output = " "
while True:
# Now do a differential reading of channels 2 and 3
voltsdiff = adc.readADCDifferential23(256, 8)
solar = (voltsdiff/70)*1000
# Display the solar irridiation
print '\r%.1f' % (solar),
sys.stdout.flush()
Would it be easier to read the data real time in a HTML document and show it in a web browser?
The Raspberry should show this screen after power-up... automatically.
Regards,
Bob
