Corvin
Wifi over TP-Link TL-WN821N v3
Thu Jul 12, 2012 10:54 pm
Hello
I have a strange issue with my TP-Link TL-WN821N v3 wifi dongle. I am powering Raspi of HTC USB charger (1.0A) and the USB wifi dongle is conected through Sandberg 7ports USB hub (powered). The problem is, that on Raspi I can see only a few wireless networks instead of whole lot I can access plugging the same dongle into my laptop. Is this may be the insufficient power supply problem? Does anybody know how much power does the TP-Link TL-WN821N v3 dongle require for proper working?
Corvin
Re: Wifi over TP-Link TL-WN821N v3
Fri Jul 13, 2012 8:34 pm
Ok. I was running some tests and I can connect easily with the provisional wifi network, which I have set up. Surprisingly the network disappears (!) when I change the broadcasting channel to 12 or 13! I cannot see any network broadcasting on those channels, so I assume it is a driver / firmware problem - anybody any help with that?
Corvin
Sat Jul 14, 2012 5:31 pm
It looks like I am alone in here... but I solved the problem! after few hours of googling and experimenting.
All I had to do was to change the local regdom of the card to allow the frequencies in GB. I have installed CRDA and edited
/etc/conf.d/wireless-regdom
adding
WIRELESS_REGDOM="GB"
after rebooting I could see all the networks and I could connect to any of them...
Problem solved!!!
You can read some more at: http://linuxwireless.org/en/developers/Regulatory/
marosg
Thu Jul 19, 2012 2:07 pm
I had the same issue with a different USB wifi adapter (some old Siemens). I managed to get it working (needed some firmware update, thank you Google). Later my connectivity just disappeared and I found a message about CRDA regulatory in dmesg. Again Google, I had to install iw package which installed also crda package (it is the latest Raspbian). I realized my country code for this regulatory stuff was set to 00. I edited /etc/default/crda file, rebooted and voila, now it keeps working.
