ric96
bcm_host.h: No such file
Tue May 12, 2015 2:40 pm
i am trying to compile tangram on my pi1 running a net-ua version of raspbian ( aka minimal raspbian net install). And i end up with the following error.
[ 48%] Building CXX object core/CMakeFiles/core.dir/src/style/polygonStyle.cpp.o
In file included from /root/tangram-es/core/src/util/vertexLayout.h:7:0,
                 from /root/tangram-es/core/src/style/style.h:7,
                 from /root/tangram-es/core/src/style/polygonStyle.h:3,
                 from /root/tangram-es/core/src/style/polygonStyle.cpp:1:
/root/tangram-es/core/src/gl.h:30:22: fatal error: bcm_host.h: No such file or directory
 #include "bcm_host.h"
compilation terminated.
core/CMakeFiles/core.dir/build.make:54: recipe for target 'core/CMakeFiles/core.dir/src/style/polygonStyle.cpp.o' failed
make[3]: *** [core/CMakeFiles/core.dir/src/style/polygonStyle.cpp.o] Error 1
make[3]: Leaving directory '/root/tangram-es/build/rpi'
CMakeFiles/Makefile2:116: recipe for target 'core/CMakeFiles/core.dir/all' failed
make[2]: *** [core/CMakeFiles/core.dir/all] Error 2
make[2]: Leaving directory '/root/tangram-es/build/rpi'
Makefile:113: recipe for target 'all' failed
make[1]: *** [all] Error 2
make[1]: Leaving directory '/root/tangram-es/build/rpi'
Makefile:160: recipe for target 'rpi' failed
make: *** [rpi] Error 2
root@pi:~/tangram-es#
pl. help
My apologies for shameless YouTube Plugs...
youtube.com/sahajsarup
twitter @sahajsarup
skype srics1996
e-mail: sahajsarup@gmail.com
Blog: http://www.geektillithertz.com/wordpress
Web: http://www.geektillithertz.com
PeterO
Re: bcm_host.h: No such file
Tue May 12, 2015 2:41 pm
What compiler switches are you using ?
PeterO
ric96
Tue May 12, 2015 2:42 pm
PeterO wrote:What compiler switches are you using ?
PeterO
using g++-4.8, the dev said to use that so......
twitter @sahajsarup
skype srics1996
PeterO
Tue May 12, 2015 2:44 pm
PeterO
Compiler switches, not compiler version.
PeterO
ric96
Tue May 12, 2015 2:47 pm
PeterO wrote:
PeterO
PeterO
how do i find out, and what is that?
[edit]
if you mean flags then...
none just simple
make rpi
the code compiles well on complete version on raspbian just error on a net-ua version
https://github.com/tangrams/tangram-es/ ... rypi.cmake
twitter @sahajsarup
skype srics1996
PeterO
Tue May 12, 2015 2:57 pm
You are trying to build on a minimal system so it is not surprising that things are missing !
My guess is that the files in /opt/vc/ and subdirectories that are needed to build code that uses the bcm_host APIs are missing.
PeterO
ric96
Tue May 12, 2015 3:03 pm
PeterO wrote:You are trying to build on a minimal system so it is not surprising that things are missing !
PeterO
Where do i get it from, github link???
twitter @sahajsarup
skype srics1996
PeterO
Tue May 12, 2015 3:11 pm
The files are included in every full Raspbian build.
I can't help any more than that as I don't have a minimal install of Raspbian to investigate.
PeterO
ric96
Tue May 12, 2015 3:12 pm
PeterO wrote:The files are included in every full Raspbian build.
PeterO
Thanks!
twitter @sahajsarup
skype srics1996
Paeryn
Tue May 12, 2015 4:34 pm
PeterO
https://github.com/raspberrypi/firmware
You probably want to copy hardfp/opt to /opt (I'm assuming the stuff listed in opt in there is compiled for softfp).
ric96
Tue May 12, 2015 4:52 pm
PeterO
Yup, worked like charm, thnx
twitter @sahajsarup
skype srics1996
john.t
Tue Feb 07, 2017 7:57 pm
Hi
This is maybe a stupid question but where do i copy this file?root?boot?
thank you
