feverish
easyGUI, anyone? Or apricots?
Sun May 10, 2015 1:29 pm
According to the web, the package to download and install easyGUI is python-easygui. So, sudo apt-get install python-easygui should do the trick? It seemed so, according to Terminal. Then, in a py script, I should be able to import python-easygui? Terminal says NO! No such thing. import easygui? Not on your Nelly! import python-easygui * ? Syntax error. Google is not my friend in this, nor are the forum searches. Is this something to do with a need for another dtoverlay, I ask myself? If so, quite what? ISTR the arabs have a saying, 'bukhra, inshallah, fi'l mishmish' . . . tomorrow, if god wishes, there will be apricots, so apricot-hopes are high right now, in this heathen mind.
If discrimination is not challenged then we are effectively in collusion with the perpetrators of such behaviour:-Oxford dictionaries
kusti8
Re: easyGUI, anyone? Or apricots?
Sun May 10, 2015 1:45 pm
According to the web, you import it as easygui. Try installing it with pip and try again as import easygui
sudo pip install easygui
Should do it.
There are 10 types of people: those who understand binary and those who don't.
mikerr
Sun May 10, 2015 1:47 pm
Install easygui:
import easygui
easygui.msgbox("hello world")
Note easygui needs x windows running...
feverish
Sun May 10, 2015 2:00 pm
mikerr wrote:Install easygui:
import easygui
Thanks. Unfortunately that's how I did install it, with the failure results I mentioned, plus trying later also to include in /boot/config.txt, when it didn't work:- dtoverlay=python-easygui
If not python-easygui, does anyone have a recent install of a close simple equivalent? I see there is a very long list of (many now-also-unsupported) equivalents.
kusti8
Sun May 10, 2015 2:02 pm
I would try installing it via pip like I showed and see if that helps.
feverish
Sun May 10, 2015 2:11 pm
kusti8 wrote:According to the web, you import it as easygui. Try installing it with pip and try again as import easygui
Should do it.
Thanks. I haven't got pip installed, so I tried sudo apt-get install pip and Terminal said there was no such packet, so now searching for a HowTo. If it works out, I'll report back later :-)
kusti8
Sun May 10, 2015 2:15 pm
Pip's package name is python-pip
feverish
Sun May 10, 2015 2:37 pm
kusti8 wrote:Pip's package name is python-pip
I think I may have become caught up in the 'python 2 or python3' wars? Pip seems to install under python 2.7 and I have python 3.4 installed here. So even after installing pip, apparently I can't use it, as Terminal still reports no such file etc. Anyway, thanks for trying, I'll try to move on to a different GUI-thing.
Jednorozec
Sun May 10, 2015 3:18 pm
If you're running python3 then you need to install python3-easygui. I installed both versions and it works for both python2 and python3. If you want to use pip for something then you need to install python3-pip.
The most important leg of a three legged stool is the one that's missing.
It's called thinking. Why don't you try it sometime?
feverish
Mon May 11, 2015 1:18 am
Jednorozec wrote:If you're running python3 then you need to install python3-easygui. I installed both versions and it works for both python2 and python3. If you want to use pip for something then you need to install python3-pip.
Ah!! Excellent. A small glimmer of light breaks through, thanks to that. I'm off to give them both a try.
feverish
Mon May 11, 2015 1:44 pm
That's where I went wrong, many thanks for the cures. Both pip and easygui now work here.
tonywaite
Fri May 29, 2015 4:27 pm
Just to sum up, choose one of the following, depending on your chosen flavour of Python:
sudo pip-3.2 install easygui
