hi everyone
I'm looking for some IC or board to manage the battery that can charge it while the pi is on.
There are tons of DC-DC charging boards but must be off when charging.
The OP did not specify what kind of battery is needed. With a sealed lead acid battery and small solar panel you can do with one battery only. This is how my @RPiAOne project works. Also in cars there is typically only one battery that is charged and used at the same time.MarkHaysHarris777 wrote:I would go with a two batt system for efficient charging and for isolation.
Well, sure... as well any laptop/notebook! I have a two batt system in my truck as well... also, I have two batts for my notebook... charging one while using the other. Its a good system, its easier on the batt and it provides great isolation for the boards. This also has some to do with the quality of the charging system and the electronic isolation provided with that solution.hampi wrote:The OP did not specify what kind of battery is needed. With a sealed lead acid battery and small solar panel you can do with one battery only. This is how my @RPiAOne project works. Also in cars there is typically only one battery that is charged and used at the same time.MarkHaysHarris777 wrote:I would go with a two batt system for efficient charging and for isolation.
swapping battery is really good way, but I just want to make it easy-to-use as possible.MarkHaysHarris777 wrote:There are lots of ways to do this. I like the method we use on the sail boat; its a two batt system with a manual (or electronic) switch-over. Basically, one batt is being used while the other batt is being charged.
Both batts are connected to the PI... the batt you're going to charge is switched to the charger, which first disengages that batt from the PI.
So, you're on BOTH, (A), or (B). When running on A you're charging B, and visav...
Charging can be solar, wind, whatever... or generator.
Another solution would be to have a DC-DC converter coming off of the batt-charger combo that would provide the proper voltage to the RPi regardless whether the charger is connected or on (charger is usually a higher voltage than the batt).
