StephenHurley
Re: STICKY: Errata
Wed Jun 13, 2018 5:47 am
Had to look up external references to see what was going on.
Apparently its got to do with changing ownership using those octal
numbers. This is done by using chmod XXX filename where XXX refer
to the octal numbers spoken about in the article.
devunwired
Re: STICKY: Errata
Wed Jul 18, 2018 4:14 am
Issue 71, Page 23 under Android Zero:
Unfortunately, Android Things does not support the Pi Zero – it requires a bit more power than the board can currently provide, so you’ll need at least a Raspberry Pi 2 to run Android Things on, but preferably a Pi 3
This statement is incorrect. Android Things only supports the Raspberry Pi 3 Model B. It will not run on a Raspberry Pi 2.
https://developer.android.com/things/hardware/
hippy
Re: STICKY: Errata
Wed Jul 18, 2018 12:38 pm
Issue 71, Page 75, line 35 of listing, wind_speed.py -
print( calculate_speed(wind_interval), "cm/h")
Should be "cm/s".
yourunclesdog
Re: STICKY: Errata
Sun Nov 04, 2018 9:53 pm
Hey there! I've just noticed that in issue 75 of the magazine, both number 36 and number 30 in the top 50 voted projects have the PolaPi-Zero's name and description. It's nothing major, I just wanted to let you know.
Return to “The MagPi”
