Distro
Executing root commands from java
Wed May 06, 2015 10:47 am
Hi everyone!
I am developing a project in which a webservice published in a TomCat server (axis2 plugin) is used, and, when it is consumed should reboot the RPi. Here the code of the command used for rebooting:
java.lang.Runtime.getRuntime().exec("sudo reboot");
In the sudoers document I have allowed the Pi user for calling admin commands without any password requeriment.
pi ALL=(ALL) NOPASSWD:ALL
I don't know why, but when I consume the webservice, it executes properly, but is not able to reboot.
The same thing when I try to modify "interfaces", it fails to change network settings.
I have tried it in Ubuntu and it work fine, so I think it must be a problem refered to the RPi's configuration.
Please, anyone could help me?
Many thanks.
ghans
Re: Executing root commands from java
Wed May 06, 2015 11:18 am
I doubt that Tomcat runs as user "pi". I recommend to read the sudo documentation and carefully only enable the "reboot" command
for the user your webservice runs as.
ghans
Distro
Wed May 06, 2015 1:27 pm
Dear ghans,
You are right. The problem related to the reboot command is solved.
Tomcat7 (our version) runs as a user called tomcat7. With just adding this line to the "interfaces" archive
tomcat7 user is allowed to use all the root commands.
tomcat7 ALL=(ALL) NOPASSWD:ALL
Thank you very much for your help.
ghans
Mon May 11, 2015 10:18 am
Please consider restricting the tomcat7 user to the two necessary commands instead giving it passwordless root privs !
http://askubuntu.com/questions/159007/h ... a-password
Start with good security practices today.
ghans
Distro
Mon May 11, 2015 10:26 am
Hi Ghans,
I only gave permission to execute the reboot function without asking for password. As you say, I thought it
would be better if that user only has a limited amount of no-password root commands.
Best regards. Thanks!
joan
Mon May 11, 2015 10:29 am
Your earlier post shows tomcat7 being granted total access which is very dangerous. A casual reader may think this is a sensible solution so your earlier post may be misleading.
Distro
Mon May 11, 2015 10:44 am
So, this is how I gave permissions to tomcat7 user (the user which apache TomCat 7 server runs on to execute a root command without being asked for the root password:
Editing "sudoers" document with the most secure method: typing the following command on the terminal => visudo
Cmnd_Alias REBOOT_CMDS = /sbin/reboot
tomcat7 ALL=(ALL) NOPASSWD: REBOOT_CMDS
I hope it fits everyone,
Regards.
Return to “Java”
