However i just have one small question... can i use my Raspberry Pi B+ power supply into the RPi2?
If i buy a new power supply, which one should i buy? How much amp and V should it be if i want to connect, my wireless mouse and keyboard?
I have a 1.8A 5V USB B power source...Laurens-wuyts wrote:I don't know what the specs are of that from your B+, but it think it should be fine.![]()
Otherwise you'll need something like 5V 2A.
Laurens
Unless you can find a manufactures data sheet, (if exists), then you will just have to try it and see.visiedo wrote:Hi,
I am about to buy a power supply for my new Raspberry Pi Model B+, since I am getting the low power indicator.
I also saw this model: DELTACO power adapter from 230V to 5V USB, 2,1A But it looks quite small. I wonder if the 2,1A are nominal or Max. And if it will reach 2,1 and still be able to maintain 5V.
Quantified:kusti8 wrote:The difference between the B+ and 2B in power is hardly noticeable.
