I intend to setup my Raspi PI 2 in that way, that it can play 4 simultaneous webstreams within the LAN. I plan to have four active house radio channels:
1) Webradio-Relay of my favorite web radio station (Antenne Bayern Chillout).
2) MP3-Playlist with selected Pink Floyd sings playing endless in repeat mode.
3) Live input from a Vigo SpeedLink (mono) playing the TV audio center box.
4) Airplay receiver to be able to http-stream airplay to every webradio in the house
In all rooms I have small radio controlled webradio modules (http://www.elv.de/elv-fs20-internet-rad ... usatz.html, starts in less than 3 seconds on LAN streams) with a smart remote control.
I could save the four "in house channels" as station keys on the remote control for every room.
Solutions, I found:
1) I found nothing for direct relaying without reencoding. IceCast relaying need to be IceCast or ShoutCast server. Works with reencoding with MPD & Icecast or MPD with httpd ouput. Tested and was ok.
2) Works with MPD & Icecast or MPD with httpd ouput.Tested and was ok.
3) Works with DarkIce & Icecast. Tested and was ok.
4) Shairplay. Could not manage to redirect audio output to IceCast or httpd in MPD.
1,2 and 4 tested with MusicBox PI (great solution!) and volumio. I could also accept three stream channels i.e. with MusicBox PI when AirPlay stops source 1 or 2.
Questions:
a) How can I setup the PI2 to be able to broadcast all four sources simultaneously as web radio streams into my LAN
b)How many sound cards do I need? (I do not use any direct sound output, every source will be web stream)
c) Can Shairplay send audio direct to IceCast?
d) How can I i.e. use three instances of mpd, each playing to its output (web radio stream) at the same time?
Thank you for every help/idea!!!
