radioman2107
Font size
Wed Jul 11, 2012 5:06 pm
Just started. Pi booted up OK except the screen display was too small to read.
ran 'startx' went to all set up /preferences I could find but so far only set some to readable size
in Geany could not alter the font. Maybe I am blind . Using a 12in HDMI tv
Any suggestions??
dom
Re: Font size
Wed Jul 11, 2012 5:21 pm
radioman2107 wrote:Just started. Pi booted up OK except the screen display was too small to read.
Any suggestions??
One solution is to limit the resolution of the framebuffer, which X uses.
E.g.
framebuffer_width=1280
framebuffer_height=720
(or lower number for larger fonts)
in config.txt
http://elinux.org/RPi_config.txt
APiFan
Re: Font size
Sat Jul 21, 2012 8:55 am
I found this on http://ncloy.co.uk/blog/?p=356
The file /etc/defaults/console-setup is where you can choose fonts for the console
sudo pico /etc/defaults/console-setup
Find the lines
FONTFACE=""
FONTSIZE=""
Change it to somthing like
FONTFACE="Terminus"
FONTSIZE="32x16"
to choose a large font
Note: this only affects the console, the font does not change until half way through the booting process when this configuration file is read.
r4049zt
Re: Font size
Sat Jul 21, 2012 3:17 pm
I got different results on first boot of an r-Pi with debian squeeze from RS vs from Farnell.
next I'll try at the text prompt after first boot
sudo nano /boot/config.txt
which might access some settings for the display screen resolution
my rPi from RS into a BENQ senseye3 monitor with HDMI did not need that settings change.
Jim JKla
Re: Font size
Sat Jul 21, 2012 3:30 pm
Further to APiFan's solution there's a detailed breakdown here in the wiki
http://elinux.org/RPi_Command_line_font_size
Noob is not derogatory the noob is just the lower end of the noob--geek spectrum being a noob is just your first step towards being an uber-geek ;)
If you find a solution please post it in the wiki the forum dies too quick
Polydnj
Re: Font size
Tue Oct 16, 2012 3:14 am
Ditto the idea of changing the resolution with framebuffer in config.txt. This changes all fonts! If it does not work try have only those lines in the config.txt
rabbitfighter81
Re: Font size
Sun Jan 19, 2014 2:17 am
See the blog post I wrote about this. May help... :geek:
http://rabbitfighter.net/?p=590
Return to “Beginners”
