peepo
disable XON XOFF termios howto?
Sat May 02, 2015 9:08 am
by default software flow control is enabled, how to disable?
minicom -b 9600 -o -D /dev/ttyAMA0 rtscts
wfm
but using termios this does not:
struct termios options;
tcgetattr(fd, &options);
options.c_iflag &= ~(IXON|IXOFF|IXANY);
cfsetispeed(&options, B9600);
cfsetospeed(&options, B9600);
tcsetattr(fd, TCSAFLUSH, &options);
I tried various combinations without success
thanks
Jonathan
PeterO
Re: disable XON XOFF termios howto?
Sat May 02, 2015 9:25 am
Have you tried setting "raw mode" ?
This is the code I normally use to configure a dumb serial port...
  serial_fd = open("/dev/ttyAMA0",O_RDWR);
  tcgetattr(serial_fd,&newtio);
  cfsetospeed(&newtio,B57600);
  newtio.c_cc[VMIN] = 0;
  newtio.c_cc[VTIME] = 0;
  cfmakeraw(&newtio);
  newtio.c_cflag &= ~CRTSCTS;
  tcsetattr(serial_fd,TCSANOW,&newtio);
PeterO
peepo
Sat May 02, 2015 11:33 am
how do I undo cfmakeraw?
seems far too strong** and did not achieve what was wanted:
ie equivalent to: minicom -b 9600 -o -D /dev/ttyAMA0 rtscts
cheers
**ie after reboot minicom is no longer typing characters...
PeterO
Sat May 02, 2015 12:58 pm
peepo wrote:how do I undo cfmakeraw?
There is nothing to "undo", termios settings only apply to the device while it is open.
As far as I can see "rtscts" is not a valid option to minicom so I don't know what you are trying to achieve. Plus PI doesn't have any hardware handshake lines anyway (AFAIK).
Where are you putting your code that changes the terminal settings ?
PerterO
man
cheers
Return to “C/C++”
