hi
Any ideas on why i can't see option 1 in config...the one used to expand file system boot to full partition size.
My options start at 2. Not overscan, can i can't select 1.
Cheers, Geoff.
If you have installed Raspbian via NOOBS, then afaiaa NOOBS undertakes the partitioning.!geoffwea wrote:hi
Cheers, Geoff.
Both Overscan and Update are in the Advanced menu, and they are numbered A1 and A9/A0. Expand Filesystem is in the main menu and numbered 1. So it is very unclear whether you are looking in the right place.geoffwea wrote:My options start at 2. Not overscan, can i can't select 1.
I've done a few rebuilds and I never see option 1. Oh, I also upgrade the tool when from memory is option 9 or something.
+1jojopi wrote: There is no logic to omit options from the menus, even if they are irrelevant. If the numbering literally starts from 2, as you may or may not be claiming, then there may be a problem with the display.
For instance if your terminal is exceptionally small (eleven lines or fewer) then option 1 may be off the top of the screen. That could also happen with very incorrect overscan settings, or if your terminal emulator is not configured correctly for cursor positioning.
