ilovemipi
Re: Kodi 15 Packages for Raspbian Wheezy & Jessie for RPi2
Fri Jan 01, 2016 10:59 pm
Tried the Jessie build and each time I run startkodi it crashes. Latest log is:
############## Kodi CRASH LOG ###############
################ SYSTEM INFO ################
Date: Sat 2 Jan 00:52:01 EET 2016
Kodi Options:
Arch: armv6l
Kernel: Linux 4.1.13+ #826 PREEMPT Fri Nov 13 20:13:22 GMT 2015
Release: Raspbian GNU/Linux 8 (jessie)
############## END SYSTEM INFO ##############
############### STACK TRACE #################
=====> Core file: /home/pi/core (2016-01-02 00:52:01.556196911 +0200)
[New LWP 733]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
Core was generated by `/usr/lib/kodi/kodi.bin'.
Program terminated with signal SIGILL, Illegal instruction.
#0 0x003e514c in xbmcutil::GlobalsSingleton<CAdvancedSettings>::getInstance() ()
Thread 1 (Thread 0xb4415230 (LWP 733)):
#1 0x003961f4 in ?? ()
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
############# END STACK TRACE ###############
################# LOG FILE ##################
Logfile not found in the usual place.
Please attach it seperately.
Use pastebin.com or similar for forums or IRC.
############### END LOG FILE ################
############ END Kodi CRASH LOG #############
Any ideas?
Sat Jan 02, 2016 12:33 am
Arch: armv6l
It looks like you've got the RPi2B version of Kodi that you're trying to run on your RPi1 (or zero). You can tell it's a RPi1 because the RPi2B would load a 4.1.13-v7+ kernel.
crystal
Tue Jan 05, 2016 8:53 am
HI Guys
I did all from first post. I install kodi from default repository on jessie latest. My rpi2 run and login automatically. Kodi trying to autorun after autologin.
if I type in terminal
after boot I have this:
pi@cloud:~ $ sudo systemctl status kodi.service -l
● kodi.service - LSB: XBMC media centre
   Loaded: loaded (/etc/init.d/kodi)
   Active: active (running) since Tue 2016-01-05 08:50:27 UTC; 16s ago
  Process: 374 ExecStart=/etc/init.d/kodi start (code=exited, status=0/SUCCESS)
   CGroup: /system.slice/kodi.service
           ├─ 407 /bin/sh /usr/bin/kodi-standalone
           ├─1504 /bin/sh /usr/bin/kodi --standalone
           └─1506 /usr/lib/kodi/kodi.bin --standalone
Jan 05 08:50:16 cloud systemd[1]: Starting LSB: XBMC media centre...
Jan 05 08:50:27 cloud systemd[1]: Started LSB: XBMC media centre.
but kodi not starting and after 1-2 minutes I can see this
   Active: active (exited) since Mon 2016-01-04 23:51:38 UTC; 8h ago
  Process: 372 ExecStart=/etc/init.d/kodi start (code=exited, status=0/SUCCESS)
Jan 04 23:51:38 cloud systemd[1]: Started LSB: XBMC media centre.
Jan 04 23:52:07 cloud sudo[1638]: pam_unix(sudo:auth): conversation failed
Jan 04 23:52:07 cloud sudo[1638]: pam_unix(sudo:auth): auth could not identify password for [kodi]
Jan 04 23:52:07 cloud sudo[1645]: pam_unix(sudo:auth): conversation failed
Jan 04 23:52:07 cloud sudo[1645]: pam_unix(sudo:auth): auth could not identify password for [kodi]
pi@cloud:~ $
if I add this line to /etc/sudoers/
kodi ALL=(ALL) NOPASSWD: ALL
I have
but kodi not starting and I have this
   Active: active (exited) since Tue 2016-01-05 08:50:27 UTC; 40s ago
Jan 05 08:51:04 cloud sudo[1622]: kodi : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/chvt 7
Jan 05 08:51:04 cloud sudo[1622]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 05 08:51:04 cloud sudo[1622]: pam_unix(sudo:session): session closed for user root
Jan 05 08:51:04 cloud sudo[1638]: kodi : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/chvt 1
Jan 05 08:51:04 cloud sudo[1638]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 05 08:51:04 cloud sudo[1638]: pam_unix(sudo:session): session closed for user root
What am I missing?
_______
Regards
Crystal :)
rjotto
Tue Jan 05, 2016 10:10 am
Hello to you all.
I am trying to install kodi on top of raspbian jessie. I looked at the official repository and the latest supported version is 15.2 but when I install it with sudo apt-get install I see 15.1. What do I need to do to install the latest official release?
Also with 15.1 when I exit from kodi I got black screen. Only when I start the program from terminal using kodi-standalone command it exits normally to the desktop.
I did the changes mentioned in the first post regarding the account and the groups.
Are there any additional configuration that needs to be done?
gkreidl
Tue Jan 05, 2016 12:31 pm
rjotto wrote:Hello to you all.
kodi-standalone is required to restore the screen.
The version in the repository is 15.1. To get 15.2 with a number of patches by popcornmix, download the version I compiled (OP). This version also contains an alternate start script (startkodi) and a patched Desktop file using it.
Minimal Kiosk Browser (kweb)
baxalo
Wed Jan 06, 2016 8:41 pm
gkreidl is any chance to compile 15.2-3-rpi2-backports (with popcornmix patches) for Wheezy?
thnks in advance..
gkreidl
Wed Jan 06, 2016 9:23 pm
baxalo wrote:gkreidl is any chance to compile 15.2-3-rpi2-backports (with popcornmix patches) for Wheezy?
thnks in advance..
if someone is willing to do that. It needs a careful checking of dependencies.
I won't because all my systems have been updated to Jessie and I don't see any reason why someone wants to stick to Wheezy,
dj_janker
Thu Jan 07, 2016 3:23 pm
Hi, I installed kodi on jessie following the steps of the first post and it works ok.
The problem is that my tv control remote don´t works....
I tried to install libcec3, but I receive this message:
pi@raspberrypi ~ $ sudo apt-get install libcec3
Reading package lists... Done
Building dependency tree
Package libcec3 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'libcec3' has no installation candidate
What´s the problem?
gkreidl
Thu Jan 07, 2016 5:48 pm
The downloaded tar file contains a number of additional packages which are needed for this version:
cec-utils_3.0.1-2_armhf.deb libcec-dev_3.0.1-2_armhf.deb
dcadec_20150816-1_armhf.deb libdvdcss_1.2.12-0_armhf.deb
libcec_3.0.1-2_armhf.deb python-libcec_3.0.1-2_armhf.deb
libcec3_3.0.1-2_armhf.deb
all of them should have been installed by the install script.
If you did not use the install script, cd into this folder and run
sudo dpkg -i *
dj_janker
Thu Jan 07, 2016 7:59 pm
I receive this error:
pi@raspberrypi ~ $ cd kodi-15-jessie
pi@raspberrypi ~/kodi-15-jessie $ sudo dpkg -i *
dpkg-deb: error: `install' is not a debian format archive
dpkg: error processing archive install (--install):
 subprocess dpkg-deb --control returned error exit status 2
(Reading database ... 119688 files and directories currently installed.)
Preparing to unpack kodi_15.2-3-jessie-rpi2-backports_armhf.deb ...
Unpacking kodi (15.2-3-jessie-rpi2-backports) over (15.2-3-jessie-rpi2-backports) ...
dpkg-deb: error: `kodi.desktop' is not a debian format archive
dpkg: error processing archive kodi.desktop (--install):
Preparing to unpack libplatform1_1.0.9-1_armhf.deb ...
Unpacking libplatform1 (1.0.9-1) over (1.0.9-1) ...
dpkg-split: error: error reading packages: Is a directory
dpkg:../../src/unpack.c:123:deb_reass
any help, please?
gkreidl
Thu Jan 07, 2016 8:48 pm
you must cd into the "packages" directory first, the run dpkg.
dj_janker
Fri Jan 08, 2016 9:04 am
Ok, you have the reason... :oops:
Now I solved the cec problem, but I can´t play video.
I only have sound. I uncheck the hardware acceleration [mmal y omxplayer], but I haven´t success
For play a local video file is necesary install any add-on?
Excuse me for the questions, but I´m a newbie....
Marco90
Tue Jan 12, 2016 7:49 pm
I have a problem with the installation of Kodi on Jessi.
Kodi works after finishing all the steps, however when I reboot the RBpi2 it gives a black screen.
gkreidl
Wed Jan 13, 2016 9:34 am
dj_janker wrote:Ok, you have the reason... :oops:
Check GPU memory (must be at least 160 MB)
gkreidl
Wed Jan 13, 2016 9:41 am
Marco90 wrote:I have a problem with the installation of Kodi on Jessi.
No idea, perhaps your SD card (file system) got damaged somehow. Doesn't it boot at all or how far do you get?
Marco90
Wed Jan 13, 2016 9:49 am
It boots, but at the moment where normally the desktop is show it just stays black.
When I reinstal the Jessie image on the SD card everything works fine again and it boots.
I've tried installing kodi a couple of times but with the same black screen after closing Kodi and after booting.
gkreidl
Wed Jan 13, 2016 10:02 am
Try installing it from the repository (version 15.1) using apt-get.
You get a black screen after closing kodi if you start it with "kodi" instead of "kodi-standalone" or startkodi (my version only).
Marco90
Wed Jan 13, 2016 12:07 pm
gkreidl wrote:Try installing it from the repository (version 15.1) using apt-get.
I've also tried that, with apt-get install kodi, but this gave the same result.
After Kodi is installed nothing works, the browser quits when entering a site and rebooting gives a black screen.
gkreidl
Wed Jan 13, 2016 12:46 pm
How did you install Raspbian Jessie (NOOBS or image)? If image, did you resize the EXT4 partition?
Marco90
Wed Jan 13, 2016 12:51 pm
gkreidl wrote:How did you install Raspbian Jessie (NOOBS or image)? If image, did you resize the EXT4 partition?
I used the image, but I didn't resize the EXT4 partition.
Could this be the problem? Is there a guide which describes how this is done?
Wed Jan 13, 2016 1:01 pm
In a terminal type "sudo rasp-config". Choose the first option. Then finish and the Pi will reboot. That's it.
gkreidl
Wed Jan 13, 2016 1:11 pm
sudo raspi-config
(There's also a GUI version now).
Marco90
Wed Jan 13, 2016 1:13 pm
Thanks for the info! I will try this tonight to see if this is the problem.
Marco90
Wed Jan 13, 2016 5:57 pm
I resized the partition and everything works fine now.
Thanks for the help!
fever3
Thu Jan 14, 2016 10:25 pm
Firstly thanks a lot for sharing your work!
I'm looking for a matching IPTV client for your KODI 15 on Jessie.
I found that you are refering to pipplware for this topic. Do you have a link to share? The link I found on one of the posts seams to be not working...
Return to “Raspberry Pi OS”
