torei
bring flash.ffu to SD card fails
Fri May 01, 2015 1:18 pm
after downloading a Win10 Desktop 32 bit and installing on a PC, i wanted to flash an SD with Win10 IoT
The given command:
dism.exe /Apply-Image /ImageFile:flash.ffu /ApplyDrive:\\.\PhysicalDrive3 /SkipPlatformCheck
Brings an error 1688: element not found.
The SD card is connected ia external USB Reader, it has 2 GB
any hints?
Re: bring flash.ffu to SD card fails
Fri May 01, 2015 2:14 pm
torei wrote:Hi,
The given command:
any hints?
http://ms-iot.github.io/content/win10/SetupRPI.htm
""A 8gb Class 10 (or better) micro SD card.""
Adieu
torei
Fri May 01, 2015 5:52 pm
Arghh! Thanks, i should have rtfm.
After all the download and setup, this got out of my eyes!
torei
Sat May 02, 2015 11:51 am
Tried it again with a 16G Card, same error.
The CMD.EXE has Admin rights
in the DISM.LOG, there are 2 error lines
- ... CGenericImagingManager::InternalCmdFFUApply
- ... CGenericImagingManager::ExecuteCmdLine
the full log is:
2015-05-02 13:42:07, Info                  DISM   PID=4620 TID=4624 Scratch directory set to 'C:\Users\Tener\AppData\Local\Temp\'. - CDISMManager::put_ScratchDir
2015-05-02 13:42:07, Info                  DISM   PID=4620 TID=4624 DismCore.dll version: 10.0.10074.0 - CDISMManager::FinalConstruct
2015-05-02 13:42:07, Info                  DISM   PID=4620 TID=4624 Successfully loaded the ImageSession at "C:\Windows\System32\Dism" - CDISMManager::LoadLocalImageSession
2015-05-02 13:42:07, Info                  DISM   DISM Provider Store: PID=4620 TID=4624 Found and Initialized the DISM Logger. - CDISMProviderStore::Internal_InitializeLogger
2015-05-02 13:42:07, Info                  DISM   DISM Provider Store: PID=4620 TID=4624 Failed to get and initialize the PE Provider.  Continuing by assuming that it is not a WinPE image. - CDISMProviderStore::Final_OnConnect
2015-05-02 13:42:07, Info                  DISM   DISM Provider Store: PID=4620 TID=4624 Finished initializing the Provider Map. - CDISMProviderStore::Final_OnConnect
2015-05-02 13:42:07, Info                  DISM   DISM Provider Store: PID=4620 TID=4624 Getting Provider DISMLogger - CDISMProviderStore::GetProvider
2015-05-02 13:42:07, Info                  DISM   DISM Provider Store: PID=4620 TID=4624 Provider has previously been initialized.  Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2015-05-02 13:42:07, Info                  DISM   DISM Manager: PID=4620 TID=4624 Successfully created the local image session and provider store. - CDISMManager::CreateLocalImageSession
2015-05-02 13:42:07, Info                  DISM   DISM.EXE:
2015-05-02 13:42:07, Info                  DISM   DISM.EXE: <----- Starting Dism.exe session ----->
2015-05-02 13:42:07, Info                  DISM   DISM.EXE: Host machine information: OS Version=10.0.10074, Running architecture=x86, Number of processors=2
2015-05-02 13:42:07, Info                  DISM   DISM.EXE: Dism.exe version: 10.0.10074.0
2015-05-02 13:42:07, Info                  DISM   DISM.EXE: Executing command line: dism.exe  /Apply-Image /ImageFile:Flash.ffu /ApplyDrive:\\.\PhysicalDrive3 /SkipPlatformCheck
2015-05-02 13:42:07, Info                  DISM   DISM Provider Store: PID=4620 TID=4624 Getting the collection of providers from a local provider store type. - CDISMProviderStore::GetProviderCollection
2015-05-02 13:42:07, Info                  DISM   DISM Provider Store: PID=4620 TID=4624 Provider has not previously been encountered.  Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider
2015-05-02 13:42:07, Info                  DISM   DISM Provider Store: PID=4620 TID=4624 Loading Provider from location C:\Windows\System32\Dism\FolderProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-05-02 13:42:07, Info                  DISM   DISM Provider Store: PID=4620 TID=4624 Connecting to the provider located at C:\Windows\System32\Dism\FolderProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-05-02 13:42:07, Info                  DISM   DISM Provider Store: PID=4620 TID=4624 Loading Provider from location C:\Windows\System32\Dism\WimProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-05-02 13:42:07, Info                  DISM   DISM Provider Store: PID=4620 TID=4624 Connecting to the provider located at C:\Windows\System32\Dism\WimProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-05-02 13:42:07, Info                  DISM   DISM Provider Store: PID=4620 TID=4624 Loading Provider from location C:\Windows\System32\Dism\VHDProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-05-02 13:42:07, Info                  DISM   DISM Provider Store: PID=4620 TID=4624 Connecting to the provider located at C:\Windows\System32\Dism\VHDProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-05-02 13:42:07, Info                  DISM   DISM Provider Store: PID=4620 TID=4624 Loading Provider from location C:\Windows\System32\Dism\ImagingProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-05-02 13:42:07, Info                  DISM   DISM Provider Store: PID=4620 TID=4624 Connecting to the provider located at C:\Windows\System32\Dism\ImagingProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-05-02 13:42:07, Info                  DISM   DISM Provider Store: PID=4620 TID=4624 Loading Provider from location C:\Windows\System32\Dism\CompatProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-05-02 13:42:07, Info                  DISM   DISM Provider Store: PID=4620 TID=4624 Connecting to the provider located at C:\Windows\System32\Dism\CompatProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-05-02 13:42:07, Info                  DISM   DISM Provider Store: PID=4620 TID=4624 Loading Provider from location C:\Windows\System32\Dism\FfuProvider.dll - CDISMProviderStore::Internal_GetProvider
2015-05-02 13:42:07, Info                  DISM   DISM Provider Store: PID=4620 TID=4624 Connecting to the provider located at C:\Windows\System32\Dism\FfuProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2015-05-02 13:42:07, Info                  DISM   DISM.EXE: Got the collection of providers. Now enumerating them to build the command table.
2015-05-02 13:42:07, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: DISM Log Provider
2015-05-02 13:42:07, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: FolderManager
2015-05-02 13:42:07, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: WimManager
2015-05-02 13:42:07, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: WimManager.
2015-05-02 13:42:07, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: VHDManager
2015-05-02 13:42:07, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: GenericImagingManager
2015-05-02 13:42:07, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: GenericImagingManager.
2015-05-02 13:42:07, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: Compatibility Manager
2015-05-02 13:42:07, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: Compatibility Manager.
2015-05-02 13:42:07, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: FfuManager
2015-05-02 13:42:07, Info                  DISM   DISM Provider Store: PID=4620 TID=4624 Getting Provider GenericImagingManager - CDISMProviderStore::GetProvider
2015-05-02 13:42:07, Info                  DISM   DISM Provider Store: PID=4620 TID=4624 Getting Provider FfuManager - CDISMProviderStore::GetProvider
2015-05-02 13:42:07, Error                 DISM   DISM Imaging Provider: PID=4620 TID=4624 base\ntsetup\opktools\dism\providers\imagingprovider\dll\genericimagingmanager.cpp:2546 - CGenericImagingManager::InternalCmdFFUApply(hr:0x80070490)
2015-05-02 13:42:07, Error                 DISM   DISM Imaging Provider: PID=4620 TID=4624 base\ntsetup\opktools\dism\providers\imagingprovider\dll\genericimagingmanager.cpp:535 - CGenericImagingManager::ExecuteCmdLine(hr:0x80070490)
2015-05-02 13:42:07, Info                  DISM   DISM.EXE: Image session has been closed. Reboot required=no.
2015-05-02 13:42:07, Info                  DISM   DISM.EXE: <----- Ending Dism.exe session ----->
2015-05-02 13:42:07, Info                  DISM   DISM Provider Store: PID=4620 TID=4624 Found the OSServices.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2015-05-02 13:42:07, Info                  DISM   DISM Provider Store: PID=4620 TID=4624 Disconnecting Provider: FolderManager - CDISMProviderStore::Internal_DisconnectProvider
2015-05-02 13:42:07, Info                  DISM   DISM Provider Store: PID=4620 TID=4624 Disconnecting Provider: WimManager - CDISMProviderStore::Internal_DisconnectProvider
2015-05-02 13:42:07, Info                  DISM   DISM Provider Store: PID=4620 TID=4624 Disconnecting Provider: VHDManager - CDISMProviderStore::Internal_DisconnectProvider
2015-05-02 13:42:07, Info                  DISM   DISM Provider Store: PID=4620 TID=4624 Disconnecting Provider: GenericImagingManager - CDISMProviderStore::Internal_DisconnectProvider
2015-05-02 13:42:07, Info                  DISM   DISM Provider Store: PID=4620 TID=4624 Disconnecting Provider: Compatibility Manager - CDISMProviderStore::Internal_DisconnectProvider
2015-05-02 13:42:07, Info                  DISM   DISM Provider Store: PID=4620 TID=4624 Disconnecting Provider: FfuManager - CDISMProviderStore::Internal_DisconnectProvider
2015-05-02 13:42:07, Info                  DISM   DISM Provider Store: PID=4620 TID=4624 Releasing the local reference to DISMLogger.  Stop logging. - CDISMProviderStore::Internal_DisconnectProvider
[/size]
torei
Sun May 03, 2015 11:37 am
Installed now W10 ADK with flash tools.
Also tried the included GUI-based Flash tool.
It does not show the Card-Writer in the device-list - but it is found in the DISKPART - list.
DISM is v.10074
Now an other message is in dism.log:
GenericImagingManager processed the command line but failed. HRESULT=FFFFFFFF
What i want to note is, that the PATH variable remained unchanged. That would mean, that the DISM utility in the Programs \ Windows Kits\10\ ... is not used?
torei
Sun May 10, 2015 9:53 am
Nobody else with that kind of Problem? :-(
jtanner_msft
Mon May 11, 2015 7:03 pm
There was one user who had a problem on one system which had set the language to Dutch, but when they tried on another system with English as the default that unblocked them:
https://social.msdn.microsoft.com/Forum ... WindowsIoT
We are looking into the error they were seeing, but for the time being maybe you could try a different system to see if you get other results.
Jonathan Tanner | Microsoft | Windows 10 IoT Core Insider Preview Support | This posting is provided 'as is' with no warranties and confers no rights.
MBRO95
Sat Jun 06, 2015 2:38 am
Here you all go:
These are taken from Windows 10 Preview ADK
1. cmd > DISKPART
2. DISKPART > LIST DISK
3. Note Disk Number of desired destination disk (we'll call it Z)
4. Download: http://1drv.ms/1KKQDdb (**Note: This includes the .ffu file for RasPi2**)
5. cmd (Admin) > cd [folder you extract the zip file to including the final DISM directory] <-- Keep Note Of This For Next Command
6. C:\Users\MBRO95\Desktop\Win10\DISM> C:\Users\MBRO95\Desktop\Win10\DISM\dism.exe /Apply-Image /ImageFile:flash.ffu /ApplyDrive:\\.\PhysicalDriveZ /SkipPlatformCheck
(**Note: Z is the disk number found from DISKPART & The full path to the dism.exe is specified in the above command**)
7. Image Successfully Written
UPDATE: Forgot the download link!
Siamak
Thu Jun 18, 2015 10:20 am
Hi every body.
I have just tried the step by step instructions written by a very knowledgeable member "MBRO95", and it worked absolutely fine, writing the image to the SD Card that is, I will give you some feedback as soon as I execute it on my RasPi 2.
Best regards to all
Siamak
girish_kumar
Fri Jun 19, 2015 7:08 am
MBRO95 wrote:Here you all go:
1. cmd > DISKPART
Thanks a lot MBRO95 your suggestions really worked I was able to boot my RPi
isziraki
Wed Jun 24, 2015 12:47 pm
I created disk successfully, but when Raspberry Pi2 boots screen is broken.
Wed Jun 24, 2015 2:14 pm
isziraki wrote:I created disk successfully, but when Raspberry Pi2 boots screen is broken.
Please explain, this is what is supposed to happen:
http://ms-iot.github.io/content/en-US/w ... tupRPI.htm
Adieu
isziraki
Thu Jun 25, 2015 1:48 pm
I followed this guide.
I created sd card in windows 7.
I tried to boot on Pi, it runs, but display doesn't appear correctly, it is broken.
kusti8
Thu Jun 25, 2015 1:50 pm
isziraki wrote:I followed this guide.
What do you see? Can you post a picture?
Saying that its broken doesn't help.
Thu Jun 25, 2015 3:25 pm
Get your SDCard on your Windows system, find the config.txt on it and add
hdmi_safe=1
save the file, eject it from your Windows system and see what happens when it boots.
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
2012-18: 1B*5, 2B*2, B+, A+, Z, ZW, 3Bs*3, 3B+
isziraki
Thu Jun 25, 2015 3:52 pm
Screen is not synchronized.
I installed Windows 10 on my laptop and create sd card again.
I have got same result.
Thu Jun 25, 2015 4:03 pm
Shutdown (or pull the power). Get the SDCard on your Windows system. Edit config.txt and add
hdmi_safe=1
save the config file and reboot it in your RPi.
MQTT Evangelist
isziraki
Thu Jun 25, 2015 4:10 pm
hdmi_safe=1
I tried it when I added hdmi_safe=1, Raspberry doesn't boot.
Thu Jun 25, 2015 4:17 pm
Then you'll need to boot it with Raspbian so that we can use the tvservice -m CEA && tvservice -m DMT command to determine what modes your HDMI monitor/TV will run with.
We can then add
hdmi_group=xxx
hdmi_mode=yyy
to config.txt on your Windows SDCard to force it into the same mode.
You could try
hdmi_group=2
hdmi_mode=4
to force it into 640x480 @60Hz.
MQTT Evangelist
isziraki
Thu Jun 25, 2015 4:40 pm
DougieLawson wrote:Then you'll need to boot it with Raspbian so that we can use the tvservice -m CEA && tvservice -m DMT command to determine what modes your HDMI monitor/TV will run with.
We can then add
hdmi_group=xxx
hdmi_mode=yyy
You could try
hdmi_group=2
hdmi_mode=4
I tried it. Start screen appears, no keyboard and mouse.
After I tried hdmi_mode=39, which is 1360x768.
I tried with wireless usb keyboard and mouse.
isziraki
Thu Jun 25, 2015 6:13 pm
Windows 10 starts, Welcome screen appears, stetting and power button are working, but I cannot do any more.
How can I make to work it.
Thu Jun 25, 2015 6:59 pm
isziraki wrote:Windows 10 starts, Welcome screen appears, stetting and power button are working, but I cannot do any more.
You login to W10 IoT Core remotely with PowerShell, bottom of this page:
Adieu
jacquephat
Fri Jun 26, 2015 7:49 am
I am trying to follow MBRO95's instructions but "dism.exe' gives me a "Access is denied" in the terminal window along with a pop-up that states "dism.exe is not a valid Windows32 application". I am using Win7 on a x64 machine.
Berndt73
Fri Jun 26, 2015 8:36 am
.....you need windows 10 to install winiot.
Who is online
Users browsing this forum: No registered users and 0 guests
