Hi guys,
I should upgrade the tables of a database through a python script.
Script and database stay on raspberry.
I found a library,Mysqldb,I try to make a script,it run,but the tables doesn't upgrande.
Thank you for your help.
Silvio
#! /usr/bin/env python
import _mysql
db=_mysql.connect("localhost","root","pinkrabbits","domotica")
db.query("UPDATE casa SET luci=1 WHERE id_stanza=1")
conn.close()Code: Select all
| Field | Type | Null | Key | Default | Extra |
| ID_stanza | int(11) | NO | PRI | NULL | auto_increment |
| nome | varchar(20) | NO | | NULL | |
| luci | tinyint(1) | NO | | NULL | |
| irrigazione | tinyint(1) | YES | | NULL | |
| finestra | tinyint(1) | YES | | NULL | |
| sensoreD | tinyint(1) | YES | | NULL | |
| sensoreA | int(11) | YES | | NULL | |
| condizionatore | tinyint(1) | YES | | NULL | |
8 rows in set (0.01 sec)
#!/usr/bin/python
import _mysql
try:
db=_mysql.connect('xxx', 'uuu', 'ppp', 'ddd')
db.query('SELECT id_stanza, luci from casa;')
res=db.use_result()
for row in res.fetch_row():
print row
except _mysql.Error, e:
print "SQL SELECT error %d: %s" % (e.args[0], e.args[1])
finally:
if db:
db.close()Code: Select all
#!/usr/bin/python
import _mysql
try:
db.query('UPDATE casa set luci=99 WHERE ID_stanza=11;')
if db.affected_rows() == 0:
raise Exception('zeroRows')
print "SQL UPDATE error %d: %s" % (e.args[0], e.args[1])
finally:
if db:
db.close()
except zeroRows, e:Code: Select all
import MySQLdb as mdb
