Andful1965
Kodi on a raspberry Pi
Thu Apr 30, 2015 12:31 pm
Hi
New to the forum so please treat me gently
I have just installed Kodi onto my pi, as I am wanting to use this as a media centre
Is it possible to install apps into Kodi like Genisis, I stream, Phoenix ? If so does any one have any idea how I can do this
The only app I have on Kodi is U tube, but for some reason I am unable to obtain video playback has any one any ideas what I am doing wrong ?
I have also read that there is a pre installed sad card with mx can / kodi reinstalled on it, I think it is called a pimbc card or something, would this be a better way to put Kodi onto my Pi and would this come with the above apps pre installed ?
Ant help appreciated Thank You
Re: Kodi on a raspberry Pi
Thu Apr 30, 2015 1:04 pm
Andful1965 wrote:Hi
Well KODI can not be installed on the RPi, please can you advise what you have installed:
XBian
OpenElec
OSMC
Raspbian with KODI Software installed
Arch with KODI software installed
topguy
So how did you do this ? The most common image to use is OpenElec, but there are alternatives like Raspbmc/OSMC. I have never heard about pimbc that you mention.
If these are standard Kodi add-ons you install them the same way as other add-ons.
https://seo-michael.co.uk/how-to-instal ... -for-xbmc/
I see that some of these requires you to install from .zip file so they are maybe not part of the standard Kodi add-on repository. It would probably be enough to put them on a usb memory stick. You could also transfer them with ssh/scp over network.
Andful1965
Fri May 01, 2015 1:07 pm
Hi I just have Rapsidan installed
Mon May 04, 2015 6:58 am
Andful1965 wrote:Hi I just have Rapsidan installed
Did you mean Raspbian ?
Install KODI software in Raspbian: viewtopic.php?f=66&t=99866
newashwin29
Mon Dec 05, 2016 5:33 am
Kodi on Raspberry pi is great and works perfectly but i prefer using Kodi on firestick. It is portable and it works perfectly...
Here is a link to install kodi on firestick
https://koditvtips.com/install-kodi-fir ... re-tv.html
Return to “Media centres”
