Thank you for sharing your thinking.
Do you see anything relevant if you run from command line?
Whenever possible I run the Pi from the command line, doing so helps me learn and spot problems.
With regard to the Bitscope / Pi operations I have not noticed anything unusual from a cmd line view. In an effort to ensure I was using a proper Raspbian image I purchased a new class 10 SD card, downloaded the latest Noobs release, conducted a Bitsum check, and followed proper procedure for the Noobs install of Raspbian. I then completed cmd-line update and upgrade steps and then executed the startx command. Finally, I followed the steps for installing the Bitscope software outlined in issue #25 of the MagPi. I did this several times, however, I was never able to get the Bitscope to run properly on the Pi.
That said, I am fairly new to Linux (~1 year) and have completed only one proper Linux training course to date; however, being retired I have spent plenty of time online learning Raspbian/Linux and resolving Pi problems using forums and other resources. At best, I am a hardware guy who is learning the software side of electronics/Pi-bonics.
Subject change.
I heard back from the Bitscope people with regard to the gridline brightness issue, their comments follow:
The will soon be updated allowing control over the selection of colours (and brightness) used for various display features including the channels, graticule (aka grid) and digital phosphor.
Previews of this release will be made available for most platforms soon and we have added your email address to the announcement release for this feature so you will be informed when it's ready (planned for June).
I will wait patiently, with hopeful expectations, for the new BitScope DSO software to be released and debugged.
With regard to the voltage measurement issue, given your consistently positive results with the Bitscope spring loaded test probes I have decided to run some additional voltage measurement tests today by swapping out the Bitscope test leads with female-to-female connectors that match up with the Bitscope connector pins and the Pi GPIO pins. Doing so should eliminate any poor connection(s) between the Pi and Bitscope that may be causing a voltage drop, and the consistently low voltage reading from GPIO pins 1 (3V3) and 2 (5V) and pin 6 ground and Bitscope display.
Taking the long view, I believe the Bitscope Micro will become a good addition to my electronics shop. In time, I believe the Bitscope people will adapt to the hobbyist market and hopefully, provide a proper user forum linked to their website. In addition, I expected to become more skilled at using a software based oscilloscope, Linux and the Pi.
I will post the results of today's Bitscope - Pi voltage measurement tests.
Thank you for your advice and guidance - of all the forums I visit the Pi foundation web site is the best by far.
Cheers
