kingsb
Can't get resolution 1080x1920 (flipped FullHD)
Mon Apr 20, 2015 4:51 pm
I'm trying to obtain full resolution on LCD display from smartphone, which is 1080x1920 pixels - it's not FullHD, because it has 1080 on X and 1920 on Y axis. But the best I can get is 1080x1200. Tried both RPI and RPI-2.
Can anyone clarify, is it possible at all?
Digging into details, that's what I did to get 1080x1200:
1. In /etc/fb.modes added the following (calculated from tvservice output for my HDMI to MIPI adapter):
# 1080x1920p hfp:18 hs:16 hbp:48 vfp:8 vs:16 vbp:10 pixel clock:136 MHz
mode "1080x1920-60"
    # D: 136.00 MHz, H: 95.200 kHz, V: 60.00 Hz
    geometry 1080 1920 1080 1920 16
    timings 7353 18 48 8 10 16 16
    #rgba 4/8,4/4,4/0,0/12
endmode
2. in /boot/config.txt added the following:
hdmi_timings=1080 0 18 16 48 1920 0 8 16 10 0 0 0 60 0 136000000 1
most of the other options in the config.txt had to be commented out, what left is:
disable_overscan=0
overscan_left=0
overscan_right=0
overscan_top=-360
overscan_bottom=-360
framebuffer_width=1080
framebuffer_height=1200
hdmi_force_hotplug=1
Trying to set all overscan values to 0 and remove framebuffer_width, framebuffer_height I'm still getting 1080x1200
beta-tester
Re: Can't get resolution 1080x1920 (flipped FullHD)
Thu Apr 23, 2015 5:30 pm
do you want to flip your monitor ?
see display_rotate option in config.txt file
http://elinux.org/RPiconfig
display_rotate rotates the display clockwise on the screen (default=0) or flips the display.
display_rotate=0        Normal
display_rotate=1         90 degrees
display_rotate=2        180 degrees
display_rotate=3        270 degrees
display_rotate=0x10000  horizontal flip
display_rotate=0x20000  vertical flip
Note: the 90 and 270 degrees rotation options require additional memory on GPU, so won't work with the 16M GPU split.
BTW: why is it posted in "Bare Metal" :?:
its more a general or trouble shooting topic
RPi Model B (rev1, 256MB) & B (rev2, 512MB) & B+, RPi2B (1GB), 64GB microSDXC1 class 10, HDMI 1920x1080, keyboard-mouse-combo (wireless), PiCamera, ethernet-cable, 5V/1.2A power supply, Wifi dongle (rt5370)
kingsb
Sat Apr 25, 2015 4:30 pm
beta-tester wrote:do you want to flip your monitor ?
Using this option I only can get 1200x1080 or 1080x1200 - please note, my display has 1080 pixels in line, 1920 lines, not as ordinary FullHD display, which has 1920 pixels in line and 1080 lines. I can suppose that 1200 is a hardware limitation, buried somewhere deep inside bcm2835 (or bcm2836 for PI2) chip. That's why I'm asking in bare metal forum.
davidcoton
Sat Apr 25, 2015 9:57 pm
Perhaps this line needs upating for the actual height? (Conjecture, not knowledge, on my part)
"Thanks for saving my life." See https://www.raspberrypi.org/forums/viewtopic.php?p=1327656#p1327656
“Raspberry Pi is a trademark of the Raspberry Pi Foundation”
kingsb
Wed May 06, 2015 10:25 am
davidcoton wrote:Perhaps this line needs upating for the actual height? (Conjecture, not knowledge, on my part)
Nope, this does not help - when I put
framebuffer_height=1920
, the resolution nevertheless resets to 1200x1080
AndyD
Wed May 06, 2015 11:38 am
You normally don't want to set framebuffer_height and framebuffer_width. On the Raspberry Pi the framebuffer is a single layer rendered by the compositor onto the display. The framebuffer width and height is independent of the display width and height. Normally, if there is no overscan settings the framebuffer width and height will be the same as the display. However, changing the framebuffer width and height doesn't change the display width and height.
Did you have a look at this thread on custom display modes?
There is mention that
So this may be the limit!
When you tried hdmi_timings did you set group and mode as follows?
hdmi_group=2
hdmi_mode=87
kingsb
Wed May 06, 2015 2:16 pm
AndyD wrote:You normally don't want to set framebuffer_height and framebuffer_width. On the Raspberry Pi the framebuffer is a single layer rendered by the compositor onto the display. The framebuffer width and height is independent of the display width and height. Normally, if there is no overscan settings the framebuffer width and height will be the same as the display. However, changing the framebuffer width and height doesn't change the display width and height.
Yes, I understand this, and I use these options only to obtain full screen access - in the price of reduced resolution on Y axis. So I can output picture on every part of the screen, but the pixel resolution is not 1:1 relative to hardware possibilities.
AndyD wrote: Did you have a look at this thread on custom display modes?
Yes, I've seen it, and used it as a start for my hdmi_timing variant
AndyD wrote: There is mention that
May be, and the next post in that thread asks:
darseneau wrote:
dom wrote: 2560x1080 is not possible. 1920x1200 is the maximum resolution supported.
Is that a firmware limitation at present, as I had supposed, or a hardware limit of the gpu?
I guess the answer to this question would put a bold point in this discussion. I have seen somewhere in the code repositories this 1200 limit for the framebuffer, but in later code it is gone, and I thought that the latest firmware would allow me to overcome this limit. Unfortunately the limit seems to be deeper in the hardware.
AndyD wrote: When you tried hdmi_timings did you set group and mode as follows?
hdmi_group=2
hdmi_mode=87
Yes, I did, but with or without this lines I obtain the same results. Since my tvservice gives the following:
[email protected]:~# tvservice -m DMT
                                            Group DMT has 2 modes:
           mode 4: 640x480 @ 60Hz 4:3, clock:25MHz progressive
  (prefer) mode 87: 1080x1920 @ 60Hz 4:3, clock:136MHz progressive
I think it does not play a big role, because system anyway choose proper mode, but then cuts vertical resolution on some later stage, and finally I obtain 1080x1200
kingsb
Wed May 06, 2015 2:51 pm
Thanks everyone, finally I managed to obtain required 1080x1920!
Reading this thread I tried the similar settings, and managed to see full resolution.
The final config.txt looks as follows:
disable_overscan=1
overscan_left=0
overscan_right=0
overscan_top=0
overscan_bottom=0
display_rotate=0
hdmi_group=2
hdmi_mode=87
hdmi_ignore_edid=0xa5000080
hdmi_cvt 1080 1920 60
max_framebuffer_width=1080
max_framebuffer_height=1920
jeroendewijs
Fri May 29, 2015 8:22 am
I new with Raspberry and Linux as well. However, I want to understand more of it and I have a simmilar problem.
I have a custom made 'monitor' made of a 5" mobile phone display 1080x1920 with HDMI controller! But the physical orientation is vertical!
So I can hook it up to a computer or whatever with a HDMI interface. But, it needs the exact resolution and frequency to work, so it does not have a scaling chip that handles lower or higher resolutions and rotation.
I can get it to work on a Windows machine with good adjustable video cards lik Nvidia. I was able to get data of the background settings using Powerstrip.
It works through HDMI 1.4 and does not have complete edid information.
Now I try to have it working with the Raspberry or any other Linux system.
I see a lot of things with config.txt and Xrandr but how to use these proppery, in what order is not clear. It looks there are other approaches as well but it confuses me how Linux handles video settings, there is not some kind of graphical tool with all these settings even if the LCD is hard to regocnize.
I tried with config.txt and Xrandr but when the raspberry boots it tries to do something with the small LCD but than stops with the boot process.
So it would be great to have some kind of script that needs to be run that allows this display to work on the raspberry.
Viking50
Thu Jul 02, 2015 8:51 am
I have the same problem, I test with :
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (87 = 1080x1920)
hdmi_cvt=1080 1920 60 3 0 0 0
hdmi_group=2
hdmi_mode=87
I have a screen with the right resolution but I have 2 black borders on the left and the right, I tried to change overscan_left and
overscan_right with negative values, but in this case I have a black screen, could you help me ?
Sincerely,
Viking50
AndyD
Thu Jul 02, 2015 11:36 am
As mentioned above, using framebuffer_width and framebuffer_height is not going to solve your problem. If you want the framebuffer to have the same dimensions as your display, then you need to disable overscan.
disable_overscan=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1080
#framebuffer_height=1920
hdmi_group=2
hdmi_mode=87
Sokolum
Wed May 25, 2016 4:30 pm
jeroendewijs wrote:Hello,
Hi Jeroen,
Did hou manage to get it working? What about the solution that was been provided by KINGSB in this thread, have you tried that out?
What kind of a driver board are you using? I like also like to buy a 1080p capable screen. I have readed that the resolution of those (smartphone) screens are representeren in 1080x1920.
Regards,
S
Lothy
Wed Jul 20, 2016 1:21 pm
kingsb wrote:Thanks everyone, finally I managed to obtain required 1080x1920!
disable_overscan=1
overscan_left=0
overscan_right=0
overscan_top=0
overscan_bottom=0
display_rotate=0
hdmi_group=2
hdmi_mode=87
Hi Kingsb,
Could you share mode details about this? Which display+hdmi adapter are you using, which raspberry and operating system?
I'm trying the same thing with a 6" monitor (1080x1920) form topfoison using a Raspberry pi 2, and so far nothing is working...
Is this which you posted here the complete config file you were using? Are there any other changes required?
Thank you,
Lothy
kingsb
Sat Jul 30, 2016 7:17 am
Lothy wrote: Could you share mode details about this? Which display+hdmi adapter are you using, which raspberry and operating system?
display: LH550WF1-SD01 panel from LG
http://www.panelook.com/LH550WF1-SD01_L ... 19410.html
HDMI-MIPI adapter: SDH-MPFH2 from Signet
http://www.signetfpd.com/adboards061913.htm
board: started with RPI-1, then moved to RPI-2, both are working
system: default installation of Raspbian from http://www.raspberrypi.org/downloads
Lothy wrote: Is this which you posted here the complete config file you were using? Are there any other changes required?
The config is complete, also I added to system/etc/fb.modes the following mode:
mode "1080x1920-60"
endmode
it corresponds to the config line
this mode only valid for this LG display, you'll need to calculate you own numbers
good luck
goudon007
Fri Dec 08, 2017 2:49 pm
Hi Kingsby,
I am using a very similar display to yours, which is a 1080*1920 full hd.
Followed similar code to yours with hdmi_timings syntax.
The problem I am facing is to set the R_pi output to 24 bit RGB.
I am trying to use this RGB data and converter them to MIPI DSI using SSD2828 chip.
It would be a great help if you can shed some light on the framebuffer_depth that you were able to achieve.
Goutham
kingsb
Thu Dec 14, 2017 8:44 am
goudon007 wrote: The problem I am facing is to set the R_pi output to 24 bit RGB.
Sorry, bro, I did not tune the framebuffer depth on this setup.
Here is the fbset output:
[email protected]:~# fbset
mode "1080x1920"
    timings 0 0 0 0 0 0 0
    rgba 5/11,6/5,5/0,0/16
endmode
as you see, it's 16 bit RGB
Thu Dec 14, 2017 10:28 am
I think by default the framebuffer is 16, you can change that with an entry in config.txt. https://www.raspberrypi.org/documentati ... t/video.md
I recently made some changes that allow correct rotation of a 1080p display, previous there was a cap at 1200 when rotating that meant the 1280 was clipped.
There is also new config.txt option. display_hdmi_rotate to specifically rotate the HDMI output but not the LCD panel.
I think these changes are all available using rpi-update, if they are not already present in the latest stretch.
Return to “Advanced users”
