acTennis
Automatically connect to open WiFi network
Sun Apr 19, 2015 2:18 pm
Hi all,
I would like my rPi can automatically connect to any open wifi network at boot. I know that editing the wpa_supplicant.def file I can choose which wifi network use but the problem is that I don't know the SSID of the open network to connect. My goal is that the rPi can connect to any open wifi network founded (sure only one network at a time).
So a standard configuration like:
# Open WiFi Network.
network={
ssid="<name_here>"
key_mgmt=NONE
priority=3
can't be used.
Can anyone help me ?
Best Regards.
Re: Automatically connect to open WiFi network
Sun Apr 19, 2015 2:36 pm
Start with https://github.com/jsh2134/iw_parse/ you should be able to hack that to update /etc/wpa_supplicant/wpa_supplicant.conf with any open networks you find.
acTennis
Mon Apr 20, 2015 6:39 am
thanks for reply it's very usefull.
Do you know if is there an equivalent script in other languages? (python is not my best)
Best Regards.
Mon Apr 20, 2015 9:37 am
There's nothing else that I've seen.
Python isn't that awful once you've got over the lack of code block delimiters {} and the insane use of left hand white space as a syntax requirement.
ghans
Mon Apr 20, 2015 10:13 am
Dooes the following entry in wpa_supplicant.conf not work ??
# This one is for connecting to any unsecured network your machine comes into contect with, just comment out if you don't like this:
network={
        key_mgmt=NONE
ghans
acTennis
Mon Apr 20, 2015 2:02 pm
the SSID fields seems to be mandatory.
mikerr
Mon Apr 20, 2015 2:47 pm
I've used the below at the end of wpa_supplicant.conf for years:
network={
        key_mgmt=NONE
        priority=-999
The low priority is to stop it connecting to an open network when there's one of my known SSIDs in range.
For reference my /etc/netowrk/interfaces is :
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
acTennis
Tue Apr 21, 2015 6:26 am
I will try your configuration and I will report my results here.
Thanks for the moment.
acTennis
Thu Apr 23, 2015 5:49 am
Hi all again,
the solution posted by mikerr seems to work but there is an open issue in my configuration.
The board boot with a WiFi adapter and DHCP configuration set in /etc/network/interfaces config file.
If a WiFi connection listed in /etc/wpa_supplicant/wpa_supplicant.conf is present at boot the rPi attach to it but if
the network is not present the rPi remain offline even if the WiFi network become available later.
In other words, only at boot che rPi join the WiFi networks, not during it's time life.
The /etc/network/interfaces file (only wifi part) is:
wlan0 auto
allow-hotplug wlan0
I miss some configuration parameters ?
Thu Apr 23, 2015 12:26 pm
You MUST have a loopback interface defined or very bad things happen.
auto lo
MrEngman
Thu Apr 23, 2015 1:31 pm
acTennis wrote:Hi all again,
wlan0 auto
allow-hotplug wlan0
First "wlan0 auto" is wrong and should be "auto wlan0". Second, you do not need both "auto wlan0" and "allow-hotplug wlan0".
Only one is needed - "allow-hotplug wlan0" is sufficient.
MrEngman
acTennis
Thu Apr 23, 2015 7:23 pm
Hi all,
I post my current interfaces file:
## Loopback interface.
auto lo
## Wired ethernet interface (DHCP).
## Wireless interface.
allow-hotplug wlan0
# wpa-roam can only be used with the manual.
## Development interface.
iface develop inet dhcp
## Customer interface.
iface wifi inet dhcp
## Default interface.
I have this processes running (only networks):
/usr/sbin/ifplugd -i wlan0 -q -f -u0 -d10 -w -I
/sbin/wpa_supplicant -s -B -P /var/run/wpa_supplicant.wlan0.pid -i wlan0 -W -D nl80211,wext -c /etc/wpa_supplicant/wpa_supplicant.conf -C /var/run/wpa_supplicant
/sbin/wpa_cli -B -P /var/run/wpa_action.wlan0.pid -i wlan0 -p /var/run/wpa_supplicant -a /sbin/wpa_action
dhclient -v -pf /run/dhclient.wlan0.pid -lf /var/lib/dhcp/dhclient.wlan0.leases wlan0
acTennis
Sat Apr 25, 2015 3:54 pm
Hi all,
now the WiFi network attaches a network also after boot sequence (so it is solved).
For the WiFi open network , in my case set:
network={
        key_mgmt=NONE
        priority=-999
doesn't work.
DineshSam
Sun Nov 12, 2017 6:25 pm
Hi, I’m new to Raspberry pi & linux. I don’t know much about coding but i can understand by reading.
I also want my pi to auto connect to open wifi network. Can you help me to do that? Please post here a step by step coding. I connect to my pi via SSH from my computer.
PLEASE.
