dgaub
GUI - Raspberry PI 2 - ArchLinux
Fri Apr 17, 2015 10:41 pm
Not a newbie. Have used Linux (Fedora, Ubuntu, Debian, etc.) for more than a decade, but I am new to Arch Linux.
I successfully installed Arch on an SD card using these directions:
http://archlinuxarm.org/platforms/armv7 ... berry-pi-2
Then, I tweaked my installation with these guidelines (written for the earlier Raspberry):
http://qdosmsq.dunbar-it.co.uk/blog/201 ... pberry-pi/
All is well except the GUI. I've checked the ArchLinux Wiki and other resources, Cannot get a response with the "startex" command; prompt says, "command not found." Tried to install xorg-init ("sudo pacman -Sy xorg-init"). Message comes back that core, extra, community, alarm, and aut are up to date, but "target not found: xorg-init."
What am I missing?
Thanks.
RobHenry
Re: GUI - Raspberry PI 2 - ArchLinux
Sat Apr 18, 2015 12:48 am
dgaub wrote:Cannot get a response with the "startex" command; prompt says, "command not found."
Is that a typo or are you really typing startex instead of startx?
dgaub
Sat Apr 18, 2015 3:18 am
Yes, a typo. Should be "startx."
Sat Apr 18, 2015 5:10 am
Arch Linux Arm by default is a Command Line Distribution, a Desktop Environment needs to be installed ;)
adieu
My other Computer is an Asus CS10 ChromeBit
RobHenry
Sat Apr 18, 2015 7:43 am
You must be missing one of the plethora of x* packages required. I think xorg-xinit contains startx - have you got that?
Edit: command you quote above is incorrect, it should be:
sudo pacman -S xorg-xinit
The -y option updates the master package list, similar to update option with apt-get
eriktheitalian
Sat Apr 18, 2015 11:09 am
My advice is xfce (4.12) with lightdm.
U can search for true package names from here:
http://archlinuxarm.org/packages
I'm not remember all steps. But i can write some about them
#U need add user with this. Add user with your selected username(change "username" include), select password.
useradd -m -g users -G stroage,power,wheel -s /bin/bash "username"
# u need use "pacman -S " with list ( sample pacman -S xfce4 )
xfce4
xfce4-goodies
xf86-video-fbturbo-git
lightdm
lightdm-gtk-greeter
xorg-server
xorg-server-utils
xorg-xinit
xorg-twm xorg-xclock xterm
# May be i'm not totaly true for this list. There is can be mistake.
# After reboot u can select xfce from lighdm login menu.
# If u need need sudo command for terminal ( Write for login: root, for password: root, after su command )
su
sudo leafpad /etc/sudoers
# Add/change there. Use your login name for yourusername
root ALL=(ALL) ALL
yourusername ALL=(ALL) ALL
Defaults:yourusername !authenticate
I cant using enough English language. My writings can be wrong grammer.$
"in micro$oft we not trust"
dgaub
Sat Apr 18, 2015 11:40 am
Thanks. I'll try those steps.
pickfire
Mon Apr 20, 2015 9:53 am
The base package are important too.
pacman -S base base-devel
If you want to you omxplayer:
pacman -S omxplayer-git
To find packages in the alarm repositories:
pacman -Sl alarm
dorbach
Thu Jun 28, 2018 7:56 pm
How do you install the desktop interface?
Return to “Arch”
