I started a script that starts at bootup, simple script, but the contents run in an infinite loop.
I thought I could use ctrl+c to stop it... I was wrong
Right now I can't exit that script, so I can't access the terminal. Anything I should do?
Did that, what is that suppose to do? I just see the cursor flashing on the screen now.klricks wrote:try Ctrl-Alt-F2
It should give you a login prompt then console after login.Whereis404 wrote:Did that, what is that suppose to do? I just see the cursor flashing on the screen now.klricks wrote:try Ctrl-Alt-F2
All the logins on the virtual consoles are started up AFTER rc.local has finished executing. If the OP's script neverklricks wrote:It should give you a login prompt then console after login.Whereis404 wrote:Did that, what is that suppose to do? I just see the cursor flashing on the screen now.klricks wrote:try Ctrl-Alt-F2
