simpic_pi
Fresh Image - No 1w Devices
Fri Apr 17, 2015 1:06 pm
Some thing really bad happened to my previous image, everything got very curropted and no python scripts would run.
I have wiped the SD and installed a fresh Wheezy image from the official download page.
If I now do the following...
sudo modprobe w1-gpio
sudo modprobe w1-therm
And then...
pi@raspberrypi /sys/bus/w1/devices $ cat /sys/bus/w1/devices/28-*/w1_slave
cat: /sys/bus/w1/devices/28-*/w1_slave: No such file or directory
Nothing, nada.
If I plug the 1w header into another pi it picks everything up, so the devices themselves and the wiring are not a problem.
Can anyone advise on a resolution route?
Re: Fresh Image - No 1w Devices
Fri Apr 17, 2015 4:21 pm
Have you enabled 1-wire in the Device Tree by putting
dtoverlay=w1-gpio
in /boot/config.txt?
simpic_pi
Fri Apr 17, 2015 6:10 pm
Thanks,
Kinda works, I get something back from the w1 DIR now, just not all the devices only one that does not seem to be reading anything.
00 00 0b 00 12 00 00 00 00 : crc=c7 NO
00 00 00 00 00 00 00 00 00 t=0
I'll re check all the wiring.
Regards,
Simpic
